Old 08-05-2010, 04:29 PM
fatal-exception's Avatar
fatal-exception is on a distinguished road
Using the Err/Res signal to e-stop Mach3?
Hi all,
I've been wondering if this is possible for a long time now. Here's the situation: My spindle is a servo motor driven by a G320. The problem I have occasionally is that if the spindle becomes overloaded and stalls, Mach3 doesn't know this, keeps on trucking, and snap...broken tool.
Is it possible to somehow use the err/res signal from the spindle g320 to signal back to the breakout board if the driver goes into fault mode? I can obviously configure Mach3 to watch a pin on the BOB and e-stop if the condition is right. Also, how would I reset the gecko after this condition? Would I need an external push button switch?
Can someone do a hand sketch of how I would wire this? Or maybe there's a wiring diagram for this already existing out there somewhere???
I have a CG11 breakout board from cnc4pc.
Thanks a bunch.
Paul
G540 E-stop and Mach3 Astroguy Gecko Drives 24 02-02-2012 10:10 PM
Need Help!- E-Stop, Probotix PBX-RF, and Mach3 jeffmorris DIY-CNC Router Table Machines 18 11-21-2010 11:40 AM
Mach3 Home Switches do not stop motors evsourcef Mach Mill 1 07-03-2010 05:26 PM
command the signal generator to start and to stop the Powermax 1650 ARTE CORTE Torchmate 2 02-19-2010 02:28 PM
Need Help!- E-Stop Rockcliff Board w Mach3 dragonstone@sym Rockcliff Machine 15 01-16-2010 09:15 PM
