Old 07-02-2003, 06:34 AM
jimglass is on a distinguished road
Changing steps
Hi;
How does one change from full step to half step and so on?
What are the benefits and disadvantages of changing steps?
My 3-axis CNC mill is fully functional now. Setting the max speeds and accel and decel were somewhat of a challenge. Each stepper has different settings for speeds. Is that normal?
Thanks again,
Jim Glass
Old 07-02-2003, 09:16 AM
balsaman's Avatar
balsaman is on a distinguished road
It is normal because each axis has different drag etc.
Eric
I wish it wouldn't crash.
Old 07-02-2003, 08:20 PM
abasir's Avatar
abasir is on a distinguished road
Changing from full step to half step and others are done at controller level. Mine can be set to full, half & quarter step. Going from full step to half step reduce your step size by half. It also 'suppose' to minimise resonance (smaller steps instead of large once) but depends on controller design. OTOH, your PC need to send double the number of pulse for the same distance.
Stupid questions make me smarter...
See how smart I've become at www.9w2bsr.com ;-P
Cause For Losing Steps? FLUTE HEAD TurboCNC 7 06-14-2005 08:54 AM
Machining small steps. pcsimp Bridgeport and Hardinge Mills 3 05-25-2005 12:36 AM
need help fet3 driver motor is choppy and slow at low steps per inch mike10 Stepper Motors and Drives 7 01-02-2005 03:41 PM
Steps per inch formula, What I am doing wrong? Noah Gecko Drives 13 05-27-2004 07:56 PM
Lost Steps How does it Happen? High Seas General Electronics Discussion 1 01-30-2004 09:57 PM
