Old 07-04-2010, 12:03 AM
bead's Avatar
bead is on a distinguished road
Gecko 203V heatsink
Ok so I tried to get some heat sinks off of some equipment at work (scrapped equipment) but the fin spacing on both pieces are not working out for me. They are too close together and I cant get a good spot to drill holes to bolt the drives down.
Is there a good piece of heat sink that you guys can recommend?
Old 07-04-2010, 06:59 PM
charliel is on a distinguished road
Newegg has a Rosewill RCX-Z80-AL 80mm heatsink-fan combination for $7.99+$3 shipping.
The flat base is 2 5/8 by 3 inch-slightly bigger than the 2.5-inch-square G203V. I would add Arctic Silver paste between the Gecko and the heatsink.
I bought four for less than $43 including shipping.
http://www.newegg.com/Product/Produc...82E16835200042
Old 07-04-2010, 11:19 PM
bead's Avatar
how do you mount it to the surface of the heatsink though? the fins look really close together
Old 07-07-2010, 02:05 PM
The flat surface opposite the fan must press against the surface of the Gecko drive (if you use four drives you need four heatsinks). These heatsinks come with a rocker bar through the center of the heatsink that has a square hole on each end. I'd recommend a bolt through the cabinet that goes through these square/rectangle holes on each side of the gecko. You could use any other method to press the heatsink against the side of the gecko that needs to be cooled-see the gecko documentation to determine which side that is and make sure the heat sink is attached to the side needing the cooling.
Need Help!- WTF C11G Gecko 203V georgeburns DIY-CNC Router Table Machines 17 06-05-2008 10:57 AM
pac-sci and gecko 203v JKuhn Gecko Drives 0 10-06-2007 11:42 PM
Gecko 201, 202, 203V vs WS-2H090M Goose80 Gecko Drives 2 01-20-2007 01:14 PM
Gecko - CPU HeatSink Cooling Fan? stdly Gecko Drives 2 02-17-2006 04:38 PM
Gecko Heatsink...How hot will it get? bobgerman Gecko Drives 4 09-13-2005 06:14 PM
