I just got a G540 and now have all 3 axis running. I've tried adjusting the trim pots, according to the Rev4 manual, but never come across a "null" or "sweet spot" point as I have seen mentioned. I have the trim pots adjusted all the way clockwise. Going counter clockwise just increases the drive's vibration. Any clue on why I can't get to that "sweet spot"? Mach3 Setup Kernel Speed: 25KHz Steps/inch: 2780 Velocity: 172 in/min Acceleration: 40 in/sec/sec Step Pulse: 2us Dir Pulse: 2us This is on a Zenbot, which has a belt drive. Last edited by gpraceman; 07-03-2010 at 08:57 AM. |
| The reason i asked... One late night had similar unsorted vibration. Next morning metered resistors, had missed them by one decade. Very little chance of the same problem with your three amp requirement. Mine were being over driven. Sure that you have rechecked your cabling. Might try backing the velocity and acceleration way down to see the effect. |
| I used the DB9 breakouts from Soigeneris. They have a trim pot to set the resistance. I made sure to double check the setting with my DMM before putting the back shells on. I put a dab of fingernail polish on the tops of the trim pots, so they would not get out of adjustment over time. I've rechecked the wiring many times. The motors are wired in the same way that I had them for another driver board that I had first tried (had to return it as it kept dropping the Z head all the way down). I tried following the instructions in the Rev4 manual on adjusting the trim pots, which mentions tuning at 2 revs/sec. If I calculated correctly, that would be about 172 in/min (0.695 turns/inch). Nothing was indicated about what acceleration to use. I just used the recommended starting point setting from the Zenbot manual (30-40 in/sec/sec). Of the 3 axis, Z is the smoothest, but still a little rough. EDIT: Not sure what is up, this forum replaces "Soigeneris" with "cnczone" in the URL. |
| Would be happy to work through the numbers with you, if you can bear with my typing on this phone. Not very familar with the zenbot. Just looked at their web. "set the axis being adjusted to move at 2 revolutions per second" Did not find the tooth count for drive pulley. See that it is 3/8" wide belt. What is the tooth count or pitch diameter of the drive pulley? 3/8" belt is normally .1 per tooth, so tooth count times .1" would be inches per revolution. Usually travel speed is expressed in inches per minute so 2 rps is the same as 120 rpm. If drive pulley is 10 tooth, 120 rpm would require 120 ipm (inches per minute) If drive pulley is 20 tooth, 120 rpm would require 240 ipm (inches per minute) |
| It would appear to me that your machine travels from one end to the other in about 3 seconds? I think that in order to tune the Geckos properly, they need to be running at a continuous 120rpm while you make the adjustment. Your machine is so small and fast that it's nearly impossible to do.
| According to the manual that I got with the machine (not the same one they have posted on their site), the pulley diameter is 0.458" and circumference is 1.439". They state that this means it rotates 0.695 turns/in. They do not list a tooth count. At a 10 micro-step setting for the G540, the Zenbot manual lists a steps per inch of 2780, which is what I have set in Mach3. |
#10
| I'd program it to run continuously back and forth while you adjust it.
#11
Well, been having my better half jog it back and forth while I was trying to adjust the trim pots. The best results, at the current settings, is with the pots all the way turned clockwise. Haven't reached any "null" or "sweet spot" point that people have described. |
#12
| Sorry was in holding pattern, my number finally came up. Looks like Gerry has been taking good care of you though. "pulley diameter is 0.458" and circumference is 1.439" In mxl belt would be 18 tooth pulley. If it is a 18 tooth pulley, the math seems about right. 18*.08=1.44 inch travel per rev. 1/1.44=0.69444 rev per inch of travel You can do a basic check of your Mach linear factor settings. Measure the actual travel without regard for acceleration or velocity. Start with axis close to one end. Measure with a tape measure or yardstick between axis fixed point and point on moving gantry. Zero axis counter in your controller software. Jog exactly ten inches on that axis per the counter. Measure again between the previous points. Should be real close to ten inches. If not, determine which setting is wrong. What Gerry is suggesting is to run a short program to move the axis. Sorry only example found right now is from a Fanuc VMC post setup. Trimmed most out, and set spindle to zero rpm. All you should need is the specific axis commands. Gerry is a guru, he can provide a much better program, with a sub call or in G91 incremental. He will also know what default modals you need in the header for Mach. O0210 (cycle x axis 0 to 10 to 0) G00 G49 G40 G17 G80 G50 G90 M03 S0 F172 G01 X10 G01 X0 G01 X10 G01 X0 G01 X10 G01 X0 G01 X10 G01 X0 M00 M30 Add as many G01 X10, G01 X0, as you need. Or just rerun the program. This would allow you to tune without stressing the boss. |
| Servo drive to drive Vibration Unit | kiwiavi | Servo Motors and Drives | 1 | 07-15-2010 06:56 AM |
| Severe Bar Vibration in A20/C-320 | danrudolph | CNC Swiss Screw Machines | 14 | 07-05-2010 01:09 AM |
| Problem- Fanuc Spindle Drive Vibration | Mickey__D | Fanuc | 3 | 03-08-2010 09:36 AM |
| Vibration Problems | jpmassey | CNC Plasma and Waterjet Machines | 9 | 09-30-2007 02:48 AM |
| Too much vibration with my X2. | alexccmeister | Benchtop Machines | 11 | 06-04-2007 01:36 PM |
