Old 05-27-2005, 11:19 AM
anthony is on a distinguished road
gecko 210: low current draw?
curiosity more than anything, as my table seems to be running fine:
i'm running two 6amp steppers via two Gecko 210's.
they're each wired with 270k resistors ie, 6A.
when i measure the current draw from the powersupply, its about
1 amp for each gecko.. even at top (table) speed.
again, 6amp rated motors seem to be running fine.
am i missing something?
or does this imply that i could've built this table with 2amp rated
steppers (ie cheaper)?
-anthony
Old 05-27-2005, 12:45 PM
ViperTX is on a distinguished road
If you're not looking at something besides a current meter....you're missing alot.
Old 05-28-2005, 02:19 AM
will my fuses miss it too?
Drive current to low? CRFultz Gecko Drives 7 04-29-2005 10:33 PM
Motor calculations jevs General Electronics Discussion 25 03-21-2005 01:05 PM
Gecko power supply 2/3" current rating? JFettig Gecko Drives 4 01-06-2005 08:04 AM
Active High/Active Low Sanghera General Electronics Discussion 21 11-06-2004 08:47 PM
