Results 1 to 8 of 8
Thread: Gecko power supply
    Feb 2005
    UK
    Gecko power supply
    Hi all,
    I am thinking of buying gecko drives, i currently have a 48vdc 12.5a power supply, i will be running 4 motors off this supply, the steppers are 2phase 2 amps a phase, now this gives me a total of 16a of current for the motors, so the power supply is producing 78% of current required by the motors, but i read on geckos website that no more than 67% of total current should be used on the boards,
    So my question is:
    How can i use this power supply, i dont know much about electronics, so i dont think i could adjust psu to output less current, dont even know if this is possible, any suggestions would be appreciated.
    DEEDEE
    Aug 2004
    Gecko's have their own current limiting resistors that you'll have to select for the older Gecko's, you'll be fine with this power supply just as it is.
    May 2005
    Where can I find a good power supply to use with Gecko servo drives? I would like to stay under the $200 mark but I don't know if it's possible.
    Thanks in advance for any help that can be offered.
    Registered bkukowski's Avatar
    May 2005
    Illinois, USA
    build one. all you nee is a power supply, fuse, rectifier, and capactior. you can find the parts on alliedelec.com (although i'm not sure about the capacitor.) there should be plenty of diagrams on how to make one. just use the search
    router finally being built!
    y axis done!
    hobbycnc controller done!
    ...mounting nsk rails and thk rail. aligning leadscrews
    Mar 2004
    Quote Originally Posted by bkukowski
    Is there a thread shows how to build one? i need a 48v 18-20amp power supply
    Gold Member widgitmaster's Avatar
    Jun 2005
    Here are two links for LARGE power supplies:
    http://transformertechnology.com/motorpowersupply.htm
    http://www.mouser.com/?Ne=601&handle...tegory&N=59703
    All are under $200 for a 75VDC 6A unregulated supply! Perfect for Gecko's
    Gold Member
    Oct 2004
    Quote Originally Posted by kburn
    What is the voltage and current ratings of the motors that you are planning to use?
    It all depends.
    My 3 steppers are 2.71 Volts at 4.6 Amps each. I used a Zicor 48 Volt 6.25 Amp supply rated at 300 watts. Works flawlessly. Guy sells them NEW on e-bay for around $35.00 $40.00 + $10.00 shipping. Zicor power supplies like this sell for about $1.50 a watt. ($450.00 Supply)
    The current settings on my drives are set at 2 amps.
    I have used these with the OMC and the Centent drives which were manufactured by Gecko. They work great.
    Jerry
    EDIT Note: I installed a large filter capacitor with bleeder on the output of the 48 Volt switching supply. Value was something like 20,000 Mfd @ 100 VDC.
    Gold Member
    Oct 2004
    I used ONE supply for the three steppers, NOT 3 supplies.
    Jerry
    1. How does a power supply work.
      By ynneb in forum DIY CNC Router Table Machines
      Last Post: 07-27-2011, 10:40 AM
    2. Gecko G201s and power supply
      By rickkun in forum Gecko Drives
      Last Post: 04-21-2005, 10:22 PM
    3. 5 Volt Power Supply Tripping
      By murphy625 in forum General Electronics Discussion
      Last Post: 02-27-2005, 10:05 PM
    4. Gecko power supply 2/3" current rating?
      By JFettig in forum Gecko Drives
      Last Post: 01-06-2005, 09:04 AM
    5. Choosing a Power Supply for Retrofit?
      By pfeist in forum General Metal Working Machines
      Last Post: 05-23-2004, 11:36 PM
