Old 06-12-2010, 03:44 PM
cncfoam is on a distinguished road
steppers or servos
I am contimplating on building a cnc wire bender. using the gecko products.
I am leaning toward servos for the fact that it will keep position.
You really wouldnt know if the stepper skipped a step.
Are there any other arguments for/or against using servo vs stepper.
I would have to gear it down, most motions will be under 360 degree angular movement. (final movement.)
Im looking for strength, torque. speed is not a priority.
thanks ahead of time.
Eric
Old 06-12-2010, 04:21 PM
SirSmash is on a distinguished road
If you can afford it (or you are going to build your own) I'd go with servo. Steppers are nice and relatively cheap but not knowing if it skips a step can get very annoying. Granted if the machine moves smoothly it really shouldn't be skipping steps.
http://torchmate.com/resource_center...s_-_the_facts/ they seem to have a good comparison.
Old 06-12-2010, 10:08 PM
ger21's Avatar
See questions 3 and 4 in the post above this one.
http://www.cnczone.com/forums/showthread.php?t=52090
Old 06-13-2010, 03:15 PM
kdoney is on a distinguished road
wire bender
cncfoam<--keep me informed. I'm just starting to make a 3d bender myself. I am going to use overpowered steppers first.
Old 06-13-2010, 09:16 PM
what stage
Where are you at on your project.
I am just researching the power requirements
as I stated, I have a hand bender bending .1875" wire,
takes 14lbs of force on a 10" handle.
trying to convert that to torque.
What are you thinking for steppers? Power?
EZ
Old 06-13-2010, 09:49 PM
WayneHill's Avatar
WayneHill is on a distinguished road
Well, drawing from my experience with steppers, they really pissed me off one day as I was working on a critical part and they skipped steps. I just about took a hammer to the stepper drives.
Use servos. Period.
Wayne Hill
www.codemangler.com
Old 06-13-2010, 11:12 PM
xclr82xtc is on a distinguished road
servos would be nice...
the problem is i cant get any freakin info on how to make them work!!! there is just WAY to much on google, alot of it unrelated...
im about to the point now where i want to write seimens a $20,000 dollar check and be done with it.
Old 06-14-2010, 10:14 AM
WayneHill's Avatar
DC servos. G320
They are easy to setup.
www.geckodrive.com
Wayne Hill
www.codemangler.com
Old 06-14-2010, 11:12 AM
geckos
I was going to use the gecko 320x. supposedly bullet proof.
I have built other cnc machines. and still have my 10 foot cnc
foam cutter.
http://www.cnczone.com/forums/showthread.php?t=16818
this is the cnc router I built a while back. this was fun.
I agree as far as understanding what to buy.
I dont know alot about other equipment but the gecko products
seem to be the best.
I am having the same problem trying to find a suitable servo.
Anybody have a good source for servos for use with gecko 320x
EZ
Steppers and servos together? Rooney Servo Motors and Drives 6 03-29-2010 07:23 AM
Steppers vs Servos Mits Spanish CNCzone 5 03-02-2007 08:26 PM
All in one steppers and servos. J Solinger LinuxCNC (formerly EMC2) 0 09-29-2006 01:42 AM
Steppers and Servos... ger21 FAQ of CNC Machine building 1 02-23-2006 09:45 PM
steppers vs. servos twombo Machine Problems, Solutions , Wireless DNC, serial port 10 06-10-2003 02:43 PM
