Old 05-24-2010, 09:23 PM
tooManyHobbies is on a distinguished road
G540 emergency stop circuits
I'm probably making things much more difficult than they need to be, but I gotta ask!
The G540 has a built-in E-Stop input, but on the Gecko Support page there is a document that also accomplishes an emergency stop using a relay and two pushbuttons. http://www.geckodrive.com/upload/Ele...nicalEStop.pdf
My question is, which method is recommended? (Best? Good enough?)
1. Only use the G540 E-Stop input.
2. Use the Electromechanical E-stop and permanently tie the G540 E-Stop input.
3. Use both.
I imagine using both could have an advantage, in that the G540 input will react quicker than the electromechanical method.
Thoughts?
tom
Old 05-24-2010, 09:56 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
3. Use both.
Thoughts?
tom
Hi Tom. That circuit is only for Servo motors, and is not needed for steppers. The G540 cannot drive servo motors. Use the G540 Estop wiring.
If you have your machine motor operated by Mach through a relay, then using the Estop will also shut down the spindle motor.
CR.
http://crevicereamer.com
Too many PMs. Email me to my name plus At A O L dot com.
Old 05-25-2010, 12:32 PM
CR.
I'm trying to find the thread that mentioned using that circuit for steppers too. It's either on this forum or the Benchtop forum. I thought it was Mariss who made the reference, but I could be wrong on all counts!
I'll proceed using only the G540s' Estop. Simpler is better.
Thanks CR.
Tom
Old 05-26-2010, 01:51 PM
Gold Member
Mariss Freimanis is on a distinguished road
The G540 has a very effective built-in E-stop circuit. When activated, it free-wheels (disconnects) all motors, shuts off the relay outputs, forces the PWM analog output to zero VDC, notifies the CNC program and lights the FAULT indicator.
Mariss
Need Help!- emergency stop error windy Bridgeport and Hardinge Mills 23 03-30-2012 10:33 AM
Need Help!- Alarm 128 QT-8 Emergency stop grabolo Mazak, Mitsubishi, Mazatrol 0 06-22-2009 01:24 PM
Need Help!- how to stop spindle in emergency Joe Miranda Milltronics 7 04-11-2008 08:03 AM
Z Axis Down During Emergency Stop L. Sakthivel Fanuc 15 07-09-2007 10:29 PM
emergency stop natchez Xylotex 0 06-15-2005 08:27 PM
