I have my G540 installed and it is running now.. WHen do we adjust the trim and how? (I know we use the small driver to turn the preset inside).
__________________ http://9w2dtr.blogspot.com/ |
| I am using Nema 23 KL23H-276-30-8B motor wired in parallel. I set the current at 3A with 3k resistor. The power supply is 48VDC. Today, I ran the G540 to cut a 6mm polycarbonate to make a bracket for the fan to cool the G540. To my surprise, it only draw up to 1.5A... why? Is adjusting the trim affect the current draw?
| Though I think it does transfer from volts to amps. I believe the setting you vary changes the voltage output to that stepper. I also wouldnt think it would draw maximum amperage unless you stalled or put maximum load on the stepper. How well did it work? Mariss? |
| From the G251 manual: http://www.geckodrive.com/upload/G251%20MANUAL.pdf ADJUSTING THE TRIMPOT This trimpot adjusts the motor for the smoothest possible low-speed operation. Set the motor speed to about 1/4 revolution per second, and then turn the trimpot until a distinct null is noted in the motor’s vibration. This will result in the most even microstep placement for a given motor and power supply voltage. It shouldnt effect the current drawn. Its hard to measure actual current drawn with a PWM drive like the gecko's unless you use a scope with a very fast sampling rate. They should pull around the same current if they are stopped or running, unless they have been stopped for long enough for the auto stand by to kick in. Lots of good info http://www.geckodrive.com/support.aspx?q=10003 |
| MrWild, I hear you. I am making a new manual for the G540 right now. It will be available online tomorrow or Friday and it covers the most common questions and problems with the G540. Is there anything you would like to see added to the manual? I am including a troubleshooting section, and if there are any common problems you would like addressed just let me know. I will post here once the manual is completed and up on the website. Marcus |
Currently the G540 manual says to run the motor at 2 revolutions per second, but on the common 0.200" pitch ball screws, that equates to (0.200" per rev * 2 revs * 60sec) 24 IPM which is no where near where this problem is occuring. I'm going to try the 1/4 rev per second (0.200" per rev * 0.25 revs * 60 sec) 3 IPM adjustment tomorrow. Hopefully this works! |
#10
| The trimpot setting does not affect taking or missing steps. It only affects motor smoothness at low speeds by adjusting the angular size of the 10th microstep to make it the same as the other 9 microsteps. Mariss |
#11
| Realizing that this is an old thread, I thought it was still appropriate to ask this question here. I've got a few days before my machine arrives. I've already got my 540 and motors, but not the power supply I'll be using. Can I do the tuning process without the motors installed on my machine and with a different power supply, 20v instead of 42v? Sounds like it should work fine since it's just tuning the last step but I wanted to make sure that the mass of the gantry and the different power supply wouldn't affect the process. Thanks Last edited by BanduraMaker; 04-17-2011 at 09:25 PM. Reason: grammar |
#12
| I'm not 100% sure, but I'd wait to do it on the machine, with the correct power supply. Steppers can act differently when mounted to the machine, especially with regards to resonance issues. Is the machine coming this week?
| g540 trim pot ?? | chrisw765 | Gecko Drives | 1 | 06-08-2009 03:47 AM |
| Trim Toolpath help | timmydabull | Mastercam | 3 | 04-04-2009 01:01 PM |
| Need Help!- surface trim | encarlisle | UG NX | 3 | 03-21-2009 02:46 AM |
| Need Help!- ?s about trim cutting. | Stampede | BobCad-Cam | 6 | 03-17-2009 11:00 AM |
| Trim | john_mccarron | EdgeCam | 3 | 11-27-2007 06:42 PM |
