Old 05-12-2005, 11:41 AM
anthony is on a distinguished road
motor won't turn
testing my setup before installation.. Gecko 210 set to microstepping locks my stepper motor when powered up. i have it set for 1amp (testing), and i'm reading 0.2A being drawn from the powersupply.
power-off and the motor unlocks.
tried this with 3 different steppers (small medium and large) and they all lock.
running Mach2 and BobCampbell's breakout board.
I have my tuning options set on the low side.
I have everything wired except the Disable terminal.
ideas?
-anthony
Old 05-13-2005, 09:29 PM
Gold Member
Mariss Freimanis is on a distinguished road
Were you the guy with the 1K current set resistor instead of the needed 10K I talked with Wednesday?
Mariss
Old 05-14-2005, 12:55 AM
from the box of mystery resistors with the faded red stripes?
don't know if i would've ever caught that myself, thanks again.
i moved up to the bigger resistor and wired the larger motor.
wasn't easy getting those 8gage wires in those little terminals.
drilled them out and now i'm golden. my 3ph 25hp motor still isn't
turning but at least its making screeching sounds now.
my geckos turned red and the silkscreened graphics have peeled off.
i couldnt' find any info about that in the troubleshooting section.
q: the 470uF/100V, aka "the flywheel". will 1000uF/63V do?
-anthony
Need help with Mazak Slant Turn 15 Univ. / Mazatrol T1' Haaatschi Machine Problems, Solutions , Wireless DNC, serial port 20 08-22-2010 12:55 AM
E-Stop Hard Wire and to Software? Sanghera General Electronics Discussion 20 10-29-2004 11:22 PM
CNC Retrofit - Kit verses turn on and go MetDetect General Metal Working Machines 21 07-12-2004 10:06 PM
circuit to turn on router head treemagnet DIY-CNC Router Table Machines 9 03-24-2004 09:15 PM
Post for Turn Master Pro software Dort Benchtop Machines 0 02-16-2004 11:35 AM
