Old 04-28-2010, 11:48 AM
Fixittt is on a distinguished road
confirm what I think I know. 6 wire motor to a g540
i found a diagram of some little steppers I have. I want to verify more then anything that I got my wirering correct.
here is a chart of the motors I have. I marked the motor wire color config and what I believe to be the correct wirering for these motors to the g540.
All I need is for someone to say YUP, your right. Or nope, your an idiot!
Name:	6 wire motor wireing.jpg‎
Old 04-29-2010, 11:39 AM
Ok so maybe that doesnt work, the motor only spins in one direction..... anyone have any ideas as to how to wire these motors or if its even possible?
Old 04-29-2010, 12:03 PM
jalessi's Avatar
jalessi is on a distinguished road
Post
Robert,
There are two ways you can connect the motor.
If you configure the motor in full winding configuration, reduce the current to 1/2 of the motor rating.
See attached pdf.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 04-29-2010, 12:21 PM
jalessi's Avatar
Post
Robert,
The current should be reduced by 1/2 if you connect the motor in full winding configuration.
Sorry for the confusion.
Jeff...
G540 with Keling 8-wire heathric Gecko Drives 6 04-08-2010 08:29 PM
Running stepper motor wire with router wire? basskitcase DIY-CNC Router Table Machines 2 02-19-2010 10:18 AM
New Machine Build- Wire stepper motors to G540 microbeast29 Stepper Motors and Drives 5 02-08-2010 04:22 AM
G540 wire size? bkboggy Gecko Drives 7 03-31-2009 12:04 AM
How to wire an 8 wire stepper motor technosteve DIY-CNC Router Table Machines 1 01-16-2009 05:01 PM
