Old 04-18-2010, 09:39 PM
salhab is on a distinguished road
G340 - Agilent encoder Problem
Hi all ,
I've been using a G320 driver with a HDES 5500 encoder successfully for the
past three years. Yesterday I decided to replace it with G340 drive to use the
step multiplier , Here the problem appeared : on one direction (X+) movement is
so smooth like always , but at the other direction (X-) motor so oscillating in
a very bad way and the driver err. lights !!!
Mariss recommends a 1uF capacitor at the encoder's power source or 1k ohm pullup
resistors at the A/B signals , I Tried both but no result !!!
Any advise ?
Old 04-18-2010, 10:15 PM
Ramu is on a distinguished road
There are some factors like proportional gain, stiffness which outcome oscillating.
Please check with your MTB to set correct values.
Varma
Old 04-18-2010, 11:16 PM
I've been successfully using the exact setup for the past 3 years , the only change is replacing G320 with G340 !!! and if I put the G320 back the system goes OK !
Old 04-21-2010, 06:28 AM
Smile
There are many Electrical parameters controlling it such as GAIN & so on.
Sorry to say but i wont be able to give you any advise on the same.
Need Help!- DMC 70V Encoder problem leike Deckel, Maho, Aciera, Abene Mills 12 03-23-2010 08:05 PM
Problem with G340 G100 evo4wrx Gecko Drives 1 10-21-2008 12:47 AM
G340 + MCG servo US enc problem XLR84x4 Gecko Drives 2 08-01-2007 06:43 AM
Encoder problem? paulend Servo Motors and Drives 5 02-06-2007 09:01 AM
Encoder problem? pauls Industrial Hobbies (Support forum) 11 12-16-2006 06:51 PM
