Im building my second router and I'm still undecided on what motor to select, narrowed down the selection to 2 units from Motionking, both are Nema34 and 8 wires: Electrical Specifications (UNI-POLAR): 34HS9801 Rated Current: 4.0 Phase Resistance: 0.98 ohm Phase Inductance: 4.1 mH Holding Torque: 490 N.cm Min and 34HS9802 Rated Current: 5.0 Phase Resistance: 0.65 ohm Phase Inductance: 2.4 mH Holding Torque: 490 N.cm Min Complete spec sheet for both motors Per Mariss empirical formula of v(max)=32 x sqrt(inductance) the voltage of both motors are within 203V capabilities, so the question is more about the inductance. Which one of these two motors would be more suitable for a 203V? my idea is to use them half coil as I will use a 4:1 reduction, but I'm open to suggestions on this matter too. Thanks a lot in advance. Pablo
__________________ ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ● |
| Nope, you're not invisible. I needed to put on my "see invisible people" glasses. I can see you just fine now.:-) Motor #1 inductance is 4.1 mH. Motor #2 inductance is 2.4 mH. Both motors have the same holding torque which means both will have the same performance when driven with what they need. So, what do they need?: Motor #1 has a maximum power supply voltage of V = 32*SQRT(4.1) or 65VDC Motor #2 has a maximum power supply voltage of V = 32*SQRT(2.4) or 49VDC Both motors will be identical in performance when driven with their respective maximum power supply voltages. Both voltages are within the specifications of the G203V drive. So how do you choose which one to use? Model the G203V as a 0.25 Ohm resistor for thermal considerations. This will determine how big of a heatsink you will need. Motor #1 is rated at 4A. I^2 * R is 4^2 * 0.25 or 4W of drive dissipation. Motor #2 is rated at 5A. I^2 * R is 5^2 * 0.25 or 6.25W of drive dissipation. Motor #2 will make the G203V drive dissipate 1.56 times more heat than Motor#1. At this point it seems Motor #2 is better; less drive heat, same performance. But wait, there are other considerations. 49VDC is awfully close to 48VDC and there are very many inexpensive off-the-shelf 48VDC available. 48VDC is a standard voltage. 65VDC is not a standard voltage. You will pay extra and you will have a difficult time finding an economical 65VDC power supply. Meanwhile the 5A motor run from a 48VDC supply will generate 2.25W more (6.25W - 4W) heat in the G203V. This is a small difference. The G203V heatsink for the 5A will be only a little bit bigger than the one for the 4A motor. If this was my problem? I would pick the 5A motor only because I could use a standard 48VDC power supply instead of a custom one. I would deal with the increased G203V heat by improving my heatsink. It would be cheaper solution than finding a 65VDC power supply. Pick the 5A per phase motor. Mariss |
| Great info Mariss..Thanks..I ordered my G203V 04 drives a couple of days ago..any feedback?
__________________ http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/ http://my-diysolarwind.blogspot.com/ |
| Anybody with experience of "Motionking" stepper motors | Gerald_D | Stepper Motors and Drives | 10 | 06-11-2011 02:58 AM |
| Difference between 201, 202, and 203V?? | flash319 | Gecko Drives | 1 | 04-20-2009 07:44 PM |
| 4 Axis Gecko 203v with 570 OZ Motors what PSU Help | Don Kellogg | Joes CNC Model 2006 | 22 | 04-01-2009 08:44 AM |
| pac-sci and gecko 203v | JKuhn | Gecko Drives | 0 | 10-06-2007 11:42 PM |
| 203v and candcnc bob? | ged | General Electronics Discussion | 1 | 02-18-2007 12:08 AM |
