Old 04-04-2010, 12:16 AM
heathric is on a distinguished road
G540 with Keling 8-wire
Has anyone used the KL23H276-30-8A motors with the G540? I'm wondering if anyone has tested the different configuration of UP, BPS, BPP.
Decided to finally hook up my G540 today and can't decide which configuration will be best. I'm using a 42v 10A PS
Thanks,
Heath
Old 04-04-2010, 02:59 AM
Pandinus is on a distinguished road
The G540 is a Bipolar driver, so...
If you go with the Bipolar Parallel you will be limited to the 3.5Amps of the G540, but you will see more usable torque at high speed due to the lower inductance...
If you just want holding power or low speed, then maybe Bipolar series...
It depends on how fast you want the motors turning. Faster is usually better
Old 04-04-2010, 04:29 AM
I like "faster"... Happy Easter!!
I guess I'll just try parallel with the full 3.5 and see what happens. It should probably be fine for my situation but hopefully parallel doesn't make everything get too hot.
I've been using the Probotix probostep drivers and they work well. After a 120 minute run my motors were usually only at about 170f. After I put 80mm fans on them they never go over 95f.
I'll have to hook it up while the rest of the family is having Easter dinner... seems like the appropriate time to get away for a while.
Thanks for the reply.
Old 04-06-2010, 02:42 AM
I hooked the G540 with my motors in BPP mode and it works ok. I seem to be getting a lot of missed steps or something though. Definitely not as strong or fast as my old drivers, which were the unipolar chopper drivers from probotix running at 3a. I never noticed it before, but if I hold the motor coupler with two fingers i can make it stall. Shouldn't they be more powerful than that?
Everything worked fine with the probotix drivers, maybe I don't have a big enough PS to run in BPP mode? it's a linear 42v 10a max (5a nominal) ps.
Old 04-08-2010, 03:31 PM
dmauch is on a distinguished road
My first guess would be that you do not have the correct current setting resistor install between pins 1 and 5 of the db9 connector.
A 3A unilpolar motor should be set for 4.2A when wired biolar parallel. You would need a 3.5K reistor for that. But the BPP is above the 3.5A that the G540 can output so you may be better off going BPS and set the current for 2.14A with a 2.2K resuistor.
Old 04-08-2010, 08:26 PM
If you are running at the full 3.5A out you "could" run it without the current set resistor... but that affects the current reduction feature of the gecko... basically disables it. Im doing that right now as I had it set up for some smaller motors on one machine, then bought some 3.5A motors for my plasma table and got lazy and snipped the resistors ... its working fine so far...
Old 04-08-2010, 08:29 PM
Oops forgot the initial problem... check to make sure that all of the phases of the motor are hooked up correctly.. if one of them is backwards it would cancel out the fields making the motor extremely weak.
Starting to wire my Keling KL-4030 drivers...QUESTIONS! BrassBuilder Benchtop Machines 22 07-20-2009 06:04 PM
G540 wire size? bkboggy Gecko Drives 7 03-31-2009 12:04 AM
I can't get my keling 387oz-in motors to step evenly with my G540 codevark Gecko Drives 0 03-16-2009 11:32 PM
Mechtronics 4 axis board and 3 Keling 8 wire steppers wgkurth Controller Cards 3 01-26-2009 10:52 PM
4 Wire Keling Steppers Confusion n1bpd Automation Technology Products 6 09-05-2008 12:58 PM
