Old 03-27-2010, 04:52 PM
Brenck is on a distinguished road
How Do I Correctly Dimension A Power Supply
Hi all,
I've read the manuals for gecko drives, I currently have G203v and I' would like to know how to correctly dimension the power supply.
I know that for voltage there is the : 32 * (√mH inductance) = Power Supply Voltage
That is ok but I'm kinda confused about the Amps of the power supply.
Lets say if I run 4 motors both the same rated 6A.
Do I build lets say a 50VDC 6A power supply or a 50VDC 24A (4x6A)?
I know I could just throw a 30Amps so I overkill the thing but I don't wanna do that and the transofrmer gets more expansive as high as you go.
Or it doesn't work that way at all...?
Thank you,
Gustavo
Old 03-28-2010, 02:31 AM
Dylwad is on a distinguished road
You take the sum of the rated current of all motors, and give them around 67% of that. So if your running 4~ 6 amp motors you would want a 16 amp supply.
http://www.geckodrive.com/upload/Step_motor_basics.pdf Page 10
Old 03-28-2010, 01:10 PM
Thank you, I haven't seen this .pdf. It helped a lot.
Tags
building, dimensioning, power supply
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
help with power supply fusiontech357 General Electronics Discussion 4 11-07-2009 08:35 AM
Newbie- Power Supply mxcapo General Electronics Discussion 4 06-15-2009 05:37 PM
More power from switching power supply R.thayer General Electronics Discussion 4 03-10-2007 07:03 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
