Old 04-29-2005, 12:20 PM
Gold Member
CRFultz is on a distinguished road
Drive current to low?
I was wondering if possible i have my current set to low. I'm trying to isolate the cause for lost steps on my x travel. it does it at random, and its always a very small amount and in both directions. Always on a straight cut. When I up'ed the feedrate it went away. I ran the machine for 25 mins straight at feedrate and rapid at 100 with a back and forth x travel (no cutting) and it never missed a beat, but the steppers were cold to the touch. Shouldn't they at least be warm?
I have a 48vdc, 25 amp power supply and the max draw with all 3 axis jogging at max is .38 of a amp.
My x and y are rated at 4.8 volt @ 2.53 amps. I'm running them at full winding.
My current set resistor is 10k. Should i give them more juice?
Chuck
Aspire, VCPro, PhotoVCarve, Cut3D, Mach3, Home built CnC.
Old 04-29-2005, 01:19 PM
ger21's Avatar
If my calculations are correct, you need ~26K resistors to get 2.5a. So your getting less than 1/2 the rated torque of the motors. You might also want to look at increasing the voltage, but it's a lot easier to increase the current first. Double check my calculations, though.
Old 04-29-2005, 01:27 PM
ViperTX is on a distinguished road
48 Volts / 26K = 2.? milliamps
You'll need something like 22 ohms at 150 watts.
Old 04-29-2005, 01:31 PM
ger21's Avatar
The formula in the Gecko docs says (47*2.53)/(7-2.53)= kohms. This is the resistor that sets the current on the Gecko, not current limiting resistors.
Old 04-29-2005, 01:33 PM
Okay, didn't notice he was using Geckos.
Old 04-29-2005, 01:53 PM
Gold Member
The docs said that if a motor is connected at full winding, the motor's phase current rating is half of its parallel or unipolar rating. I guess the motor label spec's are written at full winding.
My calculations gave me a 11k resister, I went with 10k cuz thats what i had at the time.
Ohm's law says your right so i will stick a 22k in there and see what she can do.
At half the torque it's possible the motor stalled and the result was missing steps.
Thanks again Gerry
Old 04-29-2005, 01:57 PM
ger21's Avatar
The Gecko white paper (I think the last one on the site) said the calculations were for full windings.
Old 04-29-2005, 10:33 PM
2muchstuff is on a distinguished road
I ran the numbers also and came up with what ger21 came up with, 26.6K ohms for the resistors.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Open Source CNC Controller Specification gregmary DIY-CNC Router Table Machines 28 12-04-2005 09:58 PM
gecko 210: low current draw? anthony Gecko Drives 2 05-28-2005 02:19 AM
Good DC motor and drive JRoque General Electronics Discussion 11 01-02-2005 09:38 PM
Need a low cost 4 amp, 48 volt, stepper drive Mini Miller Stepper Motors and Drives 19 12-15-2004 01:29 PM
5vdc from paralell port, not enough??? thuffner3 General Electronics Discussion 8 11-23-2004 06:07 AM
