Old 03-16-2010, 07:37 PM
vlmarshall's Avatar
vlmarshall is on a distinguished road
G540 VFD Output with KBIC?
Hello all,
I'm in the middle of a CNC router build, with a Sherline spindle and Gecko G540.
I see that the 540 has "0V to +10V opto-isolated analog output intended for use with VFD drives."
A year ago, when trying to control spindle speed on my Sherline mill with another brand of spindle control, I burned out my spindle controller and the 0-10v board because I didn't use an isolated power supply, and
Now, I've got it working on my Sherline lathe, and want speed control on the router as well. Will the Gecko handle this?
http://www.youtube.com/user/vlmarshall
Old 03-20-2010, 08:58 AM
Fastest1 is on a distinguished road
From what I have read I think it does exactly that. I think you still might need the kbic controller for the input. Did you use Homanns design for your Sherline? I run 1 of his boards on my Sherline and I also burned my first one out too. However I burned mine up hooking it up hot and bumping it up against something metal. Stupidity! Anyway the G540 does put out the correct signal to control speed.
Old 03-20-2010, 11:42 AM
vlmarshall's Avatar
I was (and, after a repair, AM ) using the CNC4PC C6 Spindle Speed Controller Card.
It has options for two different voltage inputs, one of them matched a power supply I had in the mill enclosure already, so I used it.
Crack, Fizzle, and I'd lost not only the C6, but my Control Techniques motor controller as well.
A year later, with new optoisolators in the C6, I finally put it to good use on a lathe.
I'd rather not burn out a Gecko and the router's Sherline controller if the Gecko can't handle it.
Old 03-20-2010, 06:34 PM
The gecko just supplies the signal voltage. Try an email to gecko if no answer here.
Old 03-20-2010, 07:44 PM
vlmarshall's Avatar
Yeah, that's all the C6 card does, tunable 1-10v out from a PWM signal in.
Silly G540 question: Unused output... Quazar Gecko Drives 1 03-13-2010 10:12 AM
G540 Spindle speed output voltage problem georgef8 Gecko Drives 5 09-22-2009 10:18 AM
G540 VFD output floating ? Tesla_Cubed Gecko Drives 4 08-21-2009 12:58 AM
G540 Output Help finishlinewrx Gecko Drives 5 07-10-2009 12:39 PM
Need Help!- Output command for g540 DanOSB Gecko Drives 3 02-19-2009 09:06 PM
