Old 03-13-2010, 10:54 AM
Fastest1 is on a distinguished road
Relationship of voltage of the PS?
I have a Dyna 3000, it came with (2) 24vdc 4.5A power supplies. These were wired to supply 48vdc, I am guessing at 4.5A (I am not sure there would be another amperage possible at 48vdc? with these 2 power supplies). To set up the G 540 I just used 1 of the supplies til I reconfigure the original Lambdas to 48vdc. My question is, it all works at 24vdc but when I do finally go up to the 48vdc, will speed increase or torque or both? Or would it be smarter to use the 2 supplies at a lower voltage and higher amperage in this case 24vdc @ 9A. Thanks
Old 03-13-2010, 12:05 PM
ger21's Avatar
Speed is proportional to voltage. At 0 rpm, torque is the same regardless of voltage, but as voltage increases, you'll have more torque at higher speeds.
Old 03-13-2010, 12:43 PM
so speed will increase if I double the voltage.
Old 03-13-2010, 04:25 PM
ger21's Avatar
It should.
Old 03-13-2010, 05:01 PM
Woo Hoo, maybe too early
Old 03-13-2010, 06:44 PM
It worked like a champ. Got some help from Al the Man on how to reconnect my power supplies and now I have 48vdc. It does increase speed and torque. On top of that all drivers in my G 540 work fine it was just some setting issues. Overall speed is acceptable. Still having an auto reversing problem (only on Z) but I will measure the PP output first and go from there.
New Machine Build- Backlash and Axial Play Relationship joprinz DIY-CNC Router Table Machines 12 09-20-2008 11:57 AM
Steppers and Ball Screw Relationship Mr.Chips General Electronics Discussion 5 01-01-2008 01:13 AM
Relationship of Amps to Taper Perp CNC Plasma and Waterjet Machines 0 04-10-2007 04:53 PM
Crazy inventor seeks wire EDM shop for long term relationship... InspirationTool Employment Opportunity 0 07-27-2006 09:49 AM
gas pipe & linear bearing dimensions relationship zoltan Linear and Rotary Motion 6 06-13-2005 03:12 PM
