Old 03-13-2010, 10:47 AM
Fastest1 is on a distinguished road
Stepper directional change without input
I have read as much as I could find. I see no info on why a stpper would change direction for no reason. I would suspect noise. I have raised the debounce to 1000 with no difference. All my cabling is shielded and landed to chassis ground of the machine. I do not have any limit switches connected yet either. If I jog and hold the key down it will go for a distance and for no reason will start going the other way. If I lift up on the key and press it again, it might go either direction! There doesnt seem to be a method to the madness. Ideas? Opinions? Silence doesnt work thoughThanks
Old 03-13-2010, 12:00 PM
ger21's Avatar
I don't believe that the debounce affects the dir signals. Measure the voltage on the dir pin at the drive, when jogging in both directions. It should be 0V in one direction, and 5V in the other. More than likely you're not providing enough voltage for the drive to know which direction to go.
Old 03-13-2010, 12:02 PM
Gerry is that adjustable?
Old 03-13-2010, 12:03 PM
Btw I just thought noise was the issue and tried that setting.
Old 03-13-2010, 12:08 PM
jalessi's Avatar
jalessi is on a distinguished road
Post
Fastest1,
If you have a intermittent connection on the direction pin "loose wire" that will cause what you are describing.
I have also seen a bad solder connection on a direction pin of a breakout board do the same thing.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 03-13-2010, 12:09 PM
ger21's Avatar
Is the voltage adjustable? The drive will have a voltage requirement. Most need 5V, although some will work with 3.5Volts. Depends on your drives.
Old 03-13-2010, 05:03 PM
I am sorry you are talking about the PP voltage output arent you? The drive is the G 540.
Old 03-13-2010, 05:21 PM
ger21's Avatar
Yes, the PP voltage.
Need Help!- Stepper Motor Pulse Input Problem scratali Stepper Motors and Drives 4 05-20-2012 03:07 PM
plz need help stepper no change direction chawkiz Open Source Controller Boards 0 03-07-2009 03:07 AM
31i directional 5-axis indexing?? medman Fanuc 0 09-12-2008 12:57 PM
Stepper options- would like input from the experts snapman Stepper Motors and Drives 2 04-24-2006 10:21 PM
uni-directional mold machining HuFlungDung Machine Problems, Solutions , Wireless DNC, serial port 6 05-28-2003 10:54 AM
