Old 03-10-2010, 10:26 PM
mattbesquare is on a distinguished road
72 volts through my 203V's
I am trying to complete my wiring diagram for my cnc kit. I have the keling 72 volt power supply capible of 20 amps. Running two three large steppers.
When wired, my steppers have very low resistance, do I have to set a resister inline between my gecko and my motor? Does the gecko handle the proper limiting?
Here is a (rough, incomplete but enough info) visio of what I am setting up.
This is my first experience with steppers and I Would rather not fry anything (or everything).
Thanks everyone
Old 03-10-2010, 10:36 PM
jalessi's Avatar
jalessi is on a distinguished road
Post
Matt,
The motor connects directly to the G203 with no resistors between motor and G203 drive.
Assuming all your motors are KL34H2120 the G203 will require a 282K current set resistor attached between terminals 11 & 12.
The current set resistor value determines the output current of the Gecko drive.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 03-10-2010, 10:44 PM
jalessi's Avatar
Post
Matt,
Don't forget a emergency stop switch connected to the G203 between terminal 7 and +5 volts.
Jeff...
Old 03-10-2010, 10:54 PM
Originally Posted by jalessi View Post
Matt,
Jeff...
Thank you, I was over thinking tis.
My estop, limit switches, and plugs arrived today from tokyo. Now we are cooking with crisco...
Old 03-11-2010, 09:09 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hi Matt.
You are using 2160 motors that are rated for 8.8A in BPP. Gecko does not recommend using motors greater than 7A with G203V. Setting for 7A is NO resistor.
If I were you, I would give Gecko a call, just to see if the G203V will automatically limit current to 7A. If so, your torque will fall to about 1500 Oz.
(714) 832 - 8874
CR.
http://crevicereamer.com
Too many PMs. Email me to my name plus At A O L dot com.
120 Volts? BrendaEM Industrial Hobbies (Support forum) 11 04-08-2008 08:24 PM
THC torch volts? turboboy CNC Plasma and Waterjet Machines 9 10-05-2006 06:41 PM
5 volts to 1.5 volts? ZipSnipe General Electronics Discussion 5 08-18-2006 05:18 AM
Boosting three-phase 240 Volts to 480 Volts Old Car Guy Phase Converters and VFD 6 05-01-2006 09:27 AM
24 Volts from Computer PS Jason Marsha General Electronics Discussion 2 01-18-2006 09:19 PM
