Old 03-04-2010, 04:54 PM
tiwanacote is on a distinguished road
Wiring earth/ground
Hi, I would find some answers for a few ground wiring dudes. (I made a diagram for us)
B1: Metal Geckodrive case must be isolated from "electronic metal case" wich is connected to ground (earth) by A3? (see diagram)
C2: The shield cable must be connected to negative pole from steppers 60V power supply ?
D1: 1) My stepper motor has a screw with simbol like "earth ground", where is suposed to wire it?? to A2 o B5???
2) What happen if a discharge happen between the spindle case ( in contact with the iron mill structure) and stepper motor case?
Regards!!
(Sorry for my inglish!!)
Tiwanacote
Old 03-04-2010, 05:00 PM
I will try upload the diagram later, because I can´t now
Old 03-04-2010, 10:12 PM
Gold Member
Mariss Freimanis is on a distinguished road
tiwanacote,
It's not complicated. Screw the G540 down to your control cabinet. Connect your power supply to the G540. Take one wire from your power supply GND and connect it to your control cabinet chassis. Take all of your cable shields to your power supply GND. Take a wire from your motor case back to power supply GND. That's it. It's that easy.
Mariss
Old 03-05-2010, 11:44 AM
Originally Posted by Mariss Freimanis View Post
tiwanacote,
Mariss
Mariss, thank you for your atention!
Finaly I make this diagram, please could you take a look? It is OK??
http://www.cnczone.com/forums/showth...=27363&page=55
(Pay atenttion to B1 in contact with A3 (metal case) wich is wired to earth not to stepper motor power supply ground)
Regards
Tiwanacote
Old 03-05-2010, 11:49 AM
Gold Member
I looked at your wiring diagram. Why are you using a breakout board?
Mariss
Old 03-05-2010, 11:57 AM
Al_The_Man's Avatar
On a side note, if the AC supply has a grounded neutral you normally should not fuse the neutral side, i.e. only one fuse in the 'Hot', not in both.
Old 03-07-2010, 07:21 PM
Mariss
Mariss, I´m using this electronic board from CNC4PC, http://www.cnc4pc.com/Store/osc/prod...roducts_id=161
It´s called "multifunction board" instead of "breakout board", I was wrong...
(I m not using G540, I m using G203V)
Regards
Tiwanacote
Old 03-08-2010, 08:09 PM
will gilmore is on a distinguished road
tiwanacote,
Mariss
When you say "power supply GND" are you refering to VDC-?
Old 03-08-2010, 08:11 PM
Gold Member
Yes indeed.
Mariss
Earth Sheltered or Earth Bermed homes Edwardo Environmental & Alternate Energy 8 05-06-2012 04:54 AM
Stepper wiring RE shield/ground/connector TravisR100 General Electronics Discussion 16 03-31-2009 04:57 PM
Earth Ground LYN BYRD Milltronics 5 06-20-2007 11:39 AM
Good earth ground, what is your definition? gar General Electronics Discussion 29 06-15-2005 09:22 PM
