Results 1 to 3 of 3
Thread: What can i do with a G540
    Sep 2008
    uk
    Since having struggled with my g100 im considering a g540, my question is this, i have motors rated for 90v and 4.2A (steppers) i know i can get the voltage inside the limtis of a g540 by using the correct transformer but what about the current? Steppers are constant current so take the full 4.2A all the time right? But the G540 has a current setting resistor, would that limit the currrent and stop it destroying the g540? What effect would that have on my steppers? Thanks in advance.
    Matt
    Jul 2007
    You can get 3.48K 1% resistors from DigiKey. Use those or standard 5% 3.3K resistors from Radio Shack and you will be fine as far as current limiting goes.
    Registered Crevice Reamer's Avatar
    Mar 2008
    Quote Originally Posted by matttargett4 View Post
    Matt
    Hi Matt.
    The G540, with the 3.48K resistor, will limit the motor current to 3.48A. If you use a 48V PSU, the motor will run at 48V.
    The lower Voltage will limit motor top speed somewhat. The lower Amperage will cause an 18% drop in torque. EG: If it's a 400 ounce motor, then it will detune to 331 ounces.
    CR.
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
  1. G540 HELP!!!!
    By cornbinder23 in forum Benchtop Machines
    Last Post: 01-31-2010, 09:26 AM
  2. g540
    By Scooby Doo in forum Gecko Drives
    Last Post: 05-17-2009, 02:44 PM
  3. Hot G540
    By jdemille in forum Gecko Drives
    Last Post: 05-08-2009, 01:40 PM
  4. can you... BOB to G540?
    By Fixittt in forum Gecko Drives
    Last Post: 01-28-2009, 07:37 AM
  5. G540 - WOW!
    By LaserImage in forum Gecko Drives
    Last Post: 12-04-2008, 04:30 PM
