Old 02-24-2010, 10:18 PM
Fastest1 is on a distinguished road
Just got my G540, no one has an answer?
Mariss or others, I just received my G540 and have a few questions prior to gutting my machine tomorrow. I would like to do a few things that I have seen but dont really see how to hook them up or if it ok with a gecko.
The first being a load meter, on Bob Warfields site I believe he shows a digital ammeter being used as a load meter (actually 1 for each axis) I could settle for an analog meter if that made a difference but would rather use digital. Is this ok? And if yes I would think this would be hooked up between the stepper and the controller. I will wait to see if it is ok before I ask more on that topic.
I would like to do the same with the power supply to see if there is any variance under load, no real reason besides the Wow factor and I would think that would connect between my power supply and the G540. Come on envision a single car garage, 6 motorcycles, 1 bicycle, Sherline cnc lathe, Sherline Cnc Mill, Dyna 2400 mill and a Dyna 3000 lathe with a full enclosure, flood coolant, an air powered door and 6 position tool changer? You could see why I would need a fancy control center!
Lastly, I would like to run 2 relays from the g540 and I understand how to make those work but my question is can I run a manual switch to trigger the relay and use a diode to eliminate the chance of back feeding the G540?
Any clarification on the implementation of a tach in Mach and or speed control via Mach would be great. On my Sherline I used a Digispeed board built specifically for that machine. I know he made many other boards. The motor is a SEM MT30 148 vdc which I believe has an onboard tacho sensor of some kind. Though if it has it at the motor it wouldnt have the correct ratio or rpm.
Old 02-25-2010, 10:55 AM
ger21's Avatar
Will a load meter even work with a stepper?
Old 02-25-2010, 11:52 AM
I believe it is an ammeter relabeled or are they the same. It is really just for visual effect and I am wondering about the relay/diode questions. They seem like they would work but I want to make sure.
G540 HELP!!!! cornbinder23 Benchtop Machines 21 01-31-2010 08:26 AM
g540 Scooby Doo Gecko Drives 62 05-17-2009 01:44 PM
Hot G540 jdemille Gecko Drives 1 05-08-2009 12:40 PM
can you... BOB to G540? Fixittt Gecko Drives 7 01-28-2009 06:37 AM
G540 - WOW! LaserImage Gecko Drives 6 12-04-2008 03:30 PM
