The lower the steps the smother they will run, I believe. I always ran mine in the mirco step, the steppers with not get as much top speed as a half step, but they cut much better.
Hi;
After trying out my latest CNC project, I noticed the steppers chatter at low speeds particularly when ramping up or ramping down. The steppers run very smooth at higher speeds. I know there is a trim ajustment on the Gecko 201 driver boards. Does this adjustment address the chatter?? If so, how do I adjust, trial and error??
Also, is it possible to change from full step to half or quater steps? How does one do that?
Jim
- Need Help!- help with chatter
- Newbie- help with x2 chatter,
- Chatter?
- RF noise causing stepper chatter
- Chatter
Thank You,
Paul G
Check out-
[URL="http://www.signs101.com"]www.signs101.com[/URL]
