Many simple SCR (across the line) DC controllers do not have isolation from the input supply when feeding the internal control logic.
This is fine when the speed is controlled from a self contained pot.
If interfacing with a source that provides analogue control then isolation is needed.
The rest of the machine and motor frame etc, should be at earth ground potential.
