vernn,
The OUTPUTs on the G540 are functionally SPST switches to GND. You can set your multimeter to a continuity test and measure between TERMINAL 5 or 6 and TERMINAL 12; you should read OPEN if the G540 is not powered. If the G540 is being toggled on those pins you should read between OPEN and CONTINUITY on the multimeter. What are you getting from your multimeter with those measurements?
