Need Help! G540 + PNP tool lenght probe - No input
Results 1 to 1 of 1
Thread: G540 + PNP tool lenght probe - No input
    Dec 2017
    Switzerland
    Default G540 + PNP tool lenght probe - No input
    unfortunately I got PNP probe which seems to be a bit more difficult to hook up - however I found instructions (see pic) that should help but not quite.....
    This is the product:
    https://www.sorotec.de/shop/Z-Finder...--NC-6865.html
    It has separate 12V power supply. G540 is running 48V. Funny thing is that electronics 'work': when no tool contact there is 0V between pin12(GND) and pin4 (input4) and 9V when tool is down but g540/Mach3 dont register it ???????. However if I put 5V from another external power source to pin12(-) and pin4 (+) Mach3 sees it.
    I used different transistor BC182B NPN and 5600ohm resistors.
    Why input dont register the change from 0 to 9V?
    Attached Thumbnails Attached Thumbnails G540 + PNP tool lenght probe - No input-2n2222a-connections-jpg
