Need Help! Gecko board 540 with 5A stepmotor?
Results 1 to 2 of 2
Thread: Gecko board 540 with 5A stepmotor?
    Nov 2017
    Denmark
    Default Gecko board 540 with 5A stepmotor?
    Hi
    I'm going to build a CNC machine and considering buying a Gecko board 540. I have step motors and drivers. It is 5A stepper motors.
    Is it possible to get a gecko board that is identical to a 540 board, with the ability to connect external drivers to, rather than the G250 X drivers that are in a standard 540 board. Or is it possible to connect a 540 board to 5A stepmotors? It is not necessary for motor to provide 100%.
    Here are the specifications of the engines and drivers we want to use
    Step Motor Driver
    https://www.omc-stepperonline.com/st...t-dma860h.html
    stepper motors
    https://www.omc-stepperonline.com/hy...s59-5004s.html
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Gecko board 540 with 5A stepmotor?
    With a 5a motor, you'll only get about 70% of the rated holding torque (3.5a/5a).
    No, you can't get a g540 that work with external drives, but a breakout board will do the same thing.
    UCCNC 2017 Screenset
