Need Help! G540 Mach 3 - Moved to new PC having issues
Results 1 to 2 of 2
Thread: G540 Mach 3 - Moved to new PC having issues
    Jul 2016
    Default G540 Mach 3 - Moved to new PC having issues
    My PC is dieing so I moved mach to another old PC I had laying around.
    Its running XP, I set the port to EPP. I installed mach 3 then renamed the folder to mach.2 and then copied over my old mach 3 folder.
    Rebooted pc.
    Mach loads fine but only the Z axis works. X Y and Spindle do not work.
    I swapped the Z and Y cables and then both they both worked oddly, even when I swapped back the Y continued to work along with the Z. Until I closed mach and re launched and Y stopped working again.
    The ports and pins configs look correct its just not working.
    At this point I figure it is some LPT setting issue. I am using a built in LPT port not an add on card.
    Jul 2016
    Default Re: G540 Mach 3 - Moved to new PC having issues
    Fixed it, loose wire somewhere pulled 540 out and unplugged everything and tightened everything back up and seems ok now
