And here are the photos of the device:
Hello everyone! I would like to show off with my custom-made CNC controller and subject it to your criticism. It is based on Gecko G540 module and purposed for driving a 3-axis milling machine with moving table or gantry, or other similar machines. Here is the specification:
Driver for motors: Geckodrive - Gecko G540
- 4-axis driver for 3,5 A max bipolar steppers
- integrated peripherals driver
- microstepping (10-step)
PC interface: Warp9 Tech Design - Ethernet SmoothStepper (no LPT port needed, communication through ethernet)
- eliminated problems with LPT and Windows "timing" issues
- huge possibilities for system upgrade (two spare LPT-alike ports left)
Computer: Lenovo 3000 C200 laptop
- WInXP SP2 (licensed)
- Mach3 (licensed)
- preconfigured system, Mach3 + plugins, SmoothStepper
Bipolar stepper motors (3 motors, 4th one possible):
- Type: NEMA23 - R57BYGH4331 (200 steps/rev)
- Current/Phase: 3,5 A max
- Motor shaft: 1/4"
- high quality motor cables
Power supplies:
- 48 V - 7,0 A (for Gecko driver motors)
- 12 V - 1,3 A (for fans and relays)
- 5 V - 3,0 A (for SmoothStepper)
- dedicated laptop power supply
- all voltages available on DIN rail connectors
2 relay blocks (for spindle, coolant etc.):
- every block is a 3PDT relay (TE Connectivity - PT370012) in DIN rail module, with flyback diode
- max 400 V AC - for 250 V AC max 10 A
--- "PC type" IN and OUT slots on panel (by-pass, fused)
- max 300 V DC - for 30 V DC max 5 A
--- "microphone type" IN and OUT slots on panel (by-pass, two poles)
Input and output connectors:
- 6 NC type "limit" switches: X++, X--, Y++, Y--, Z++, Z--
--- connected in series, "MIC type" connectors on panel
- 3 NC type "home" switches: X home, Y home, Z home
- 2 NO type digital inputs (for tool length probe etc.)
- 1 analog output 0-10 V (PWM for VFD spindle)
Other:
- mains switch with fuse, E-STOP button
- 4 fans (connected by WAGO quick connectors)
- cables organized on DIN rail WAGO connectors for easy maintenance and modification
Mechanics:
- structural aluminum profiles enclosure frame
- 2mm powder coated steel walls, fixed in profile seals
- stainless steel mounting plate
- easy access to internals without tools
- detachable transportation handles (can be used as standoffs when used vertically)
- dimensions (without handles and connectors): 540 mm x 400 mm x 135 mm
- weight (without laptop and motors): approximately 16 kg
Total project cost (including Mach3 license and own used laptop, excluding man-hours): approximately 6500 PLN / 1850 USD / 1550 EUR
This looks great ... This is exactly what I want to make for the replacement of the my existing drives/control/steppers on the Taig CNC mill I purchased used running MACH3.
Are you willing to share information / Help someone like myself who is very electronically challenged?
In fact, much of the research I have done in the past few weeks is pointing me to the purchase many of the main components you have used.
I would really appreciate being able to learn from what you have already done in making this controller base.
Thanks ... and very well done.
PeteW.
Hi Peter,
Thank you for your appreciation. And yes, I can help you with some guidance within the field of similar drivers. There are some things I have learned and if I were supposed to design a similar driver I would make some things a slightly different way. I will PM you with the details.
In touch.
Hi can yo provid a wiring diagram please.
Mike
you have made a beautiful job but why stick with Mach3? All development ceased on it six years ago, so you have a new control
box with new parts and yet its controlled by software that's out of date?
The ESS has a Mach4 plugin....try it.
Craig
Honestly, I have never drawn the full diagram. There were only my notes taken by hand on some parts which needed to be organized before assembly.
Well, when I decided to go with this project, Mach3 was still popular here in Poland, and in fact it still is.
BTW. Personally, I'd like to have a software similar to Tormach's PathPilot, or even better - something similar to Datron's soft, which will be suitable to support our mid-end home made machines with Ethernet interfaces.
