Need Help! Getting the old system running again, G540 won't come out of fault
Results 1 to 3 of 3
Thread: Getting the old system running again, G540 won't come out of fault
    Mar 2010
    Default Getting the old system running again, G540 won't come out of fault
    Eight years or so ago I built a Fineline Automation FLA-200 kit with the 4 axis nema 23 kit from cncrouterparts.com. Dan Mausch built the control box. With help from all of the above and this forum I got it built, configured, up and running and learned how to use it. Late last winter the hard drive died in it. I got another old pc, reinstalled Mach3, used the XML file I'd saved aside for that eventuality, and nothing happened. At the time I figured I was having parallel port problems, so I eventually bought an ethernet smoothstepper, which I just got around to installing now. I'm running Win 7 32 bit, the smoothstepper installed fine and is communicating fine and I got the driver setup in Mach and I believe that's working as expected. As for the G540, it stays in fault unless I turn the charge pump off, then it green lights, and if my motors are connected I can hear them power up and freeze position. But I can't get it to come out of fault. I know that the charge pump switch test only shows if you've wired it for power properly, and the step after that would be to install the stop. I have no reason to believe that the stop button has become faulty, that is, it all worked before, so in theory it should be fine now, but I feel it should be put to the test--at this point I don't know what else to do. So, please recommend what else I can do, or tell me how to test for continuity in the stop button. Can I just bypass it, see what happens? Yeah, this electronics stuff is not at all my thing.
    Thanks!
    mc
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Getting the old system running again, G540 won't come out of fault
    Make sure the charge pump is configured in Mach3, and the ESS if it needs it.
    UCCNC 2017 Screenset
    Mar 2010
    That was it, Ger, thanks--I didn't have the ESS plugin properly installed. That, an XML file Dan Mauch sent me on Saturday and the motor tuning images GhostXL posted for me however long ago and all that's left is to cut a test part. I hope! Appreciate it.
