Runaway with G320X
Results 1 to 4 of 4
Thread: Runaway with G320X
    Dec 2008
    Default Runaway with G320X
    My setup is a little weird and I have to wonder if that is the root cause of my issue. I have an external power supply for my encoders as they require more than the G320X can provide. I have gone through testing and am currently working with just my Z axis. I tested it all and hooked it all up then supplied power to my system and the Z took off until it hit the limits. I disconnect the power to the armature and go back to retest and find that I fault out when I provide power to the encoder. With the reading I did I increased the gain and tried to switch A & B signal wires but had the same results. I'm not really sure where to go from here and would really appreciate input. Thanks
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Runaway with G320X
    If it's running away, the Gecko is probably not seeing the encoder signals.
    UCCNC 2017 Screenset
    Dec 2008
    Any thought on why it faults when power is supplied to the encoder?
    Dec 2008
    I turned HEDS on after I reverified the wiring from the encoder and it no longer faults as soon as the power supply for the encoder is connected however it still takes off.....I have no idea why. Is there any chance the - signals should be used instead of the + from the encoder? The only reason I ask is the colors of the wires being used for signal. My other encoders used black from the - signal and this axis uses black for the + signal....I know I am really stretching on that one but I am at a loss.
Runaway with G320X
Runaway with G320X
