Hopefully a dumb question anot bnot wiring
Results 1 to 8 of 8
Thread: Hopefully a dumb question anot bnot wiring
    Dec 2008
    Default Hopefully a dumb question anot bnot wiring
    I have searched and searched for info regarding the anot and bnot connection and where to put them with my G320X and have not found an answer so hopefully I can get some guidance here. I am retrofitting a CNC machine where the encoders have the following wires:
    5v 0v
    A Anot
    B Bnot
    Z Znot
    5V, 0V, A and B are easy enough to figure out where they go and I think I can omit the Z and Znot signals. I am not sure what to do with the Anot and Bnot wires. When I have the G320X wired with the 5V, 0V, A and B wires I get a constant fault light on the drive which indicates a wiring problem. I remove the A and B wires and I can get the reset process to work. I am guessing the drive is seeing a wiring fault due to Anot and Bnot not being wired to anything. My best guess is the not signals go to terminal 12 however I am not sure and don't want to smoke a drive. Please help.
    Member Bubba's Avatar
    Mar 2004
    lagrange
    Default Re: Hopefully a dumb question anot bnot wiring
    Those are differential outputs for the A and B signals and have no connection to the Gecko drive.
    Simply ignore them and things will work fine.
    Art
    Dec 2008
    I wonder why I am getting a non-reset-able fault at the drive. I have verified wiring to A and B and it's all good. I get to step 3 and am stuck with setting up the drives. As soon as I remove the A and B signal wires I can reset the fault.
    Mar 2004
    lagrange
    Going strictly from memory here, but you might try reversing the servo power wires. Not the wires from the power supply.
    That would be bad.
    Art
    Dec 2008
    I tried to reverse the +5V and it's ground and the drive would not power. I have an E-mail in to Gecko and am waiting for a response.
    Mar 2004
    lagrange
    Not the logic voltage, but the Arm+ and Arm- terminals. I think that terminals 3 and 4.
    Art
  7. #7
    Dec 2008
    I haven't got that far according to the setup so I have not applied power to the armature.
  8. #8
    Mar 2004
    lagrange
    I'm not sure so hopefully Gecko will get back to you soon.
    Art
