- Momentary push button as limit wsitces?
Hello
I own the Gecko G540 controller, and wondering about limit switches- i have a 3 axis CNC machine with limit switches (they actually installed a momentary push button- N/O)- while i see everywhere limit switches connected as N/C.
how can I connect NO switches to the gecko drive? will use Mach 3 or Mach 4 to operate the system
Re: Momentary push button as limit wsitces?
You just invert the pin in the mach3 software. Machine 3 doesn't care if you use NO or NC switches, it just has to be set to know if an open or closed circuit means you are on the limit
Sent from my Z958 using Tapatalk
- You may not post replies
- You may not edit your posts
Forum Rules
