How to add speed index-hal sensor to gecko540 on Mini Mill X2?
Results 1 to 2 of 2
Thread: How to add speed index-hal sensor to gecko540 on Mini Mill X2?
    Mar 2016
    Brazil
    Post How to add speed index-hal sensor to gecko540 on Mini Mill X2?
    Hi everyone!
    I´m retrofitting my X2 mini mill to cnc with a Gecko G540
    I already know that I can control the X2 spindle speed through Mach3 using the 0-10V opto-isolated output ports of the Gecko connected to the X2 mini mill´s pot.
    I have a small and really simple hal sensor schematics to act as an index speed sensor also, which is powered by 5V. I can use an step-down voltage converter to get these 5V from the main 48V power source.
    So, is there an input on the G540 where I could connect this sensor output? How can I wire it? On those 12 main terminal block pinouts I can´t find any input for a "speed sensor", only 4 inputs for on-off switches... could one of these inputs be used for this purpose?
    Or should I wire it directly to the db25 cable on the computer side? And set Mach3 to read it independently of the G540?
    Any help will be appreciated!
    Thanks a lot!
    Mar 2016
    Brazil
    Default Re: How to add speed index-hal sensor to gecko540 on Mini Mill X2?
    I found this thread after searching a little bit more...
    Cheap and easy spindle index sensor for G540 and Mach 3
    I think it solves my problem!
