- im almost done with my DYI 5 axis machine but i have this noise issue....
Re: im almost done with my DYI 5 axis machine but i have this noise issue....
Looks like a nice scope.
You said ".....every time i plug the 5 volt logic into them...." If you are readily plugging something in and out that not a fair test. Thing will change. What you need to do is put one probe of the scope on the motor that is moving and use that wave form to trigger the scope to capture the signal of the other probe.
Ex. The motor moves and trigger the scope the other probe is on one of the input of the driver, did the wave form change, if not then look at the next point to see if it is moving.
- You may not post replies
- You may not edit your posts
Forum Rules
