You are little bit lost in the settings.
1. The number of steps is the number needed to move the table a defined distance. This is dependent on the ballscreww pitch and any gearing in place if you aren't direct driving the screw. This number is not related to the other 2 numbers.
2. Velocity is how fast the machine will move when moving at 100% jog rate.
3. Accel is setting how much time it takes to get it moving from a dead stop.
In some thread around here there is the mathematical formula for figuring out your Steps/Per setting from which to start. I can't remember it.
Velocity and Accel you will need to figure out. Start low and keep ramping them up until you get a stall condition then back them down 20%.
