Hi, after posting here I spent a lot of time trying to understand what's going on here.
1) I noticed the problem persists in all axis.
2) To isolate the problem I decided to turn off the driver and the encoder power supply for axis Y and Z.
3) I decided to tune using the Gecko procedure (here) in PID trimming, the X motor is quiet and it is not bouncing.
4) This is a close-up video, that "bump" in the motor operation happens independently of axis and I cant rid of it!
Questions:
a) I'm not sure if that problem is related to noise or ground loop....any ideas or suggestions please?
b) Should I turn my attention to any dodgy signal from my Computer+ESS? Is that really possible to have problems over the Ethernet interface?
c) The Gecko error limit switch is 1/2 of my encoder line count (500*4=2000, so I'm using 1024) is that correct?
