Gecko Drives
Page 1 of 101 12341151 ... LastLast
Threads 1 to 20 of 2012
Forum: Gecko Drives
Discuss all Gecko drives here and get direct support!
Sub-Forums Threads / Posts  Last Post
  1. G-REX
    (4 Viewing)
    Forum Actions:
    Forum Statistics:
    • Threads: 48
  1. Sticky Threads
  2. Sticky Thread Sticky: Geckodrive FAQ: General, Steppers, and Servo Questions Answered
    Started by CoAMarcus‎, 02-07-2008 09:04 PM
    000rpm, 213, 65%, almost, another, away, current draw, down, except, four, goes, indicate, keep, machinis, motor wiring, next, not, rps, say, since, then, useful, whatever
    02-07-2008, 09:04 PM Go to last post
  3. Forum Threads
  1. g540 and 201x on same machine?
    Started by bgymr‎, Yesterday 05:16 PM
    Yesterday, 07:18 PM Go to last post
  2. Geckodrive: Back to Basics and Price Drops
    Started by CoAMarcus‎, 02-02-2018 05:55 PM
    cnc, drive, manufacturing, products, unit
    02-16-2018, 06:49 AM Go to last post
  3. G540 to Consew Type Servo Sewing Machine Motor
    Started by IdefixRC‎, 08-21-2017 04:16 AM
    3 Pages
    1 2 3
    02-15-2018, 03:06 PM Go to last post
  4. Need Help!- Wiring scematic is confussing. Can someone help me please?
    Started by Ryadia‎, 05-06-2017 11:58 PM
    02-14-2018, 10:53 AM Go to last post
  5. Problem- Keep arcing chassis on Geckos??
    Started by Zeppelin1007‎, 02-09-2018 12:03 AM
    02-13-2018, 04:57 PM Go to last post
  6. Stepper motor makes chirp noise after jog, then g540 faults
    Started by QuinnSjoblom‎, 02-03-2018 10:27 PM
    2 Pages
    1 2
    g540, jog, motor, motors, noise
    02-12-2018, 09:12 PM Go to last post
  7. GR252 and the New Raptor Series of Drives
    Started by CoAMarcus‎, 02-09-2018 03:10 PM
    02-09-2018, 06:34 PM Go to last post
  8. G201s with Vexta PK296-F4.5A Motors
    Started by dsnellen‎, 02-03-2018 01:25 PM
    02-05-2018, 11:29 AM Go to last post
  9. g540 and Galt g200 vfd
    Started by Maurice‎, 01-06-2018 09:35 AM
    g200, g540, galt, software, vfd
    01-26-2018, 09:52 AM Go to last post
  10. Dual 203v
    Started by johnd‎, 01-07-2018 06:40 PM
    axis, breakout, direction, drives, signal
    01-23-2018, 03:08 PM Go to last post
  11. Need Help!- Different Voltages for G540 Inputs
    Started by Baxy‎, 01-17-2018 08:24 AM
    01-17-2018, 09:53 AM Go to last post
  12. Question Axis randomly stop working
    Started by groc426‎, 12-23-2014 02:57 AM
    art, axis, code, cut, down, fine, g-code, g203v, issues, jog, mach, mach3, motors, pin, pmdx, point, setup, spindle, stop, supply, wiring, working, yang, z-axis
    01-07-2018, 11:58 AM Go to last post
  13. Problem- Can be used G320´s with this motors ?
    Started by Ernesto411‎, 01-02-2018 08:20 PM
    01-02-2018, 08:20 PM Go to last post
  14. Gecko G212 problem
    Started by fudo66‎, 12-26-2017 07:15 AM
    01-01-2018, 06:27 PM Go to last post
  15. Post G540 Troubleshooting
    Started by vernn‎, 12-26-2017 06:45 PM
    2 Pages
    1 2
    12-28-2017, 07:23 PM Go to last post
  16. Need Help!- Gecko G540 Wiring
    Started by ronald44181000‎, 12-18-2017 10:29 PM
    g540, inlet, module, power, switch
    12-19-2017, 06:21 PM Go to last post
  17. Need Help!- Z-Axis Motor Makes Clunking Noise
    Started by CH33‎, 11-14-2017 09:39 AM
    cnc, drive, motor, noise, z-axis
    12-14-2017, 08:05 AM Go to last post
  18. Check my stepper math & stepper resonance
    Started by mikemaat‎, 03-26-2016 03:52 AM
    axis, degrees, fine, micro, step
    12-13-2017, 02:39 AM Go to last post
  19. Need Help!- G540 + PNP tool lenght probe - No input
    Started by tlaine‎, 12-06-2017 02:17 PM
    12-06-2017, 02:17 PM Go to last post
  20. Need Help!- G320X and Mesanet 7i76
    Started by pippin88‎, 04-22-2017 09:08 AM
    7i76, cnc, g320x, input, terminal
    12-03-2017, 11:21 PM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 22 users browsing this forum. (1 members & 21 guests)
  1. bgymr
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
