Results 1 to 5 of 5
Thread: Gearotic output 4th axis to MACH3
    Feb 2012
    uk
    Question Gearotic output 4th axis to MACH3
    Hi All
    Hopefully started thread ok.
    I was trying to output 1st spur gear from GEAROTIC on 4th axis to MACH3.
    1. Mach3 only shows a flat "rack" rather then full gear (yes license ok all 2000 lines in)
    2. The blank is prepared to Gear diameter
    3. Tool 3mm is set off on top and full out 3 mm of the blank (rotary table placed on the right of table facing left. so (facing --) selected. Parallel x selected.
    Result: The tool seems to cut a spiral in the blank and almost 1 complete 1 rev in between each cut rather then back and forward motion with partial rotation of the 4th axis.
    In a few words it seems just to shred the blank to pieces. Surely it's something silly...any suggestions...more than welcome
    thanks a lot in advance
    Tom
    Sep 2006
    I had a similar problem and unchecking the rotational 360 rollover in the general configuration in Mach3 got around the problem.
    Feb 2012
    uk
    many thanks
    Thanks again for usefully replying to the post.
    I also changed the direction of A axis which I thought was running right but it..wasn't.
    So in brief:
    In config general deselect rotational roll over (which in some operations needs to be on for other cutting)
    Change the A axis rotation in config / ... / a axis active low (deselected)
    Now runs well, cut on aluminum is a bit rough I guess need to play with feeding rates / rpm etc
    Thanks again
    T
    Registered neilw20's Avatar
    Jun 2007
    For situations like that, I often create a new profile, so that old programs don't get broken.
    I have one for 4th axis, and for Endmill grinding grinding.
    Different jobs need the 360 bit ticked and others don't.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Feb 2012
    uk
    Hi Neil,
    With the list of settings getting longer and longer yours, sounds like a sensible approach.
    cheers
    T
    1. Mach3 output simulation???
      By Scott Kelley in forum Mach Mill
      Last Post: 05-02-2011, 02:49 AM
    2. Vectric Cut2d output to Mach3
      By msimpson99 in forum DIY CNC Router Table Machines
      Last Post: 11-14-2010, 07:01 PM
    3. Direction output inverted in Mach3 R3.041
      By kreutz in forum Machines running Mach Software
      Last Post: 07-21-2010, 08:18 PM
    4. Which Rhino output for Mach3 mill?
      By BEIGeorge in forum Machines running Mach Software
      Last Post: 01-11-2008, 04:47 PM
    5. Help needed to customize output of Mach3
      By frenzal in forum Screen Layouts, Post Processors & Misc
      Last Post: 10-15-2006, 09:25 PM
