Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > G-Zero
G-Zero Discuss g-zero software here!
Old 08-19-2011, 08:04 AM
Perfect Circle's Avatar
Perfect Circle is on a distinguished road
G-Zero for Windows 98
I bought a used computer at a garage sell and it has the windows 98 version of G-Zero.
Not a problem using it except I have no clue as to how you import cad drawings.
Any Ideas?
Thanks for any and all replies.
Old 08-25-2011, 08:30 PM
metalmansteve is on a distinguished road
it's primarily a conversational type cam system and programming from a cad-file is not its strong suit. I don't think the earliest versions have capabilities of importing a cad file. You can use dxf files to for tool paths but it needs to be scaled and good clean geometry. You should be able to go to Tools > Cad to open a .dxf file. If it's an early version...you may not have that option.
Old 09-02-2011, 09:53 AM
Moderator
beekeeper is on a distinguished road
unless they have changed your copy will fault out and need acode to reactivate it from g-zero. Usually yearly or ever 2 years this protects the liscensed owner in case it is stolen. Not sure if there is pirated copies running around
BE NICE TO THE NERDS IN SCHOOL. THEY ONE DAY MAY BE YOUR BOSS
Need Help!- V9 with windows 7 mriker Mastercam 4 11-14-2010 09:27 PM
Build Thread- Windows 7? richcam1 BobCad-Cam 4 12-20-2009 02:48 PM
Windows 7 TravisR100 Mach Software (ArtSoft software) 3 05-22-2009 08:05 AM
Windows XP larry53 Computers and Networking 13 01-31-2008 07:48 AM
Windows XP or Windows 2000 better with Mach2 Beezer Mach Software (ArtSoft software) 2 10-18-2004 10:08 AM
