Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Gecko Drives > G-REX
  #25   Ban this user!
Old 09-08-2009, 03:44 PM
Sven_D is on a distinguished road
Tasospe
I had some connection problems with my g100 after the rabbit was replaced by Gecko, I had to replace the network card in my pc before it would reconnect.
Sven
  #26   Ban this user!
Old 09-27-2009, 12:45 PM
Larken is on a distinguished road
I don't much about the G100, but sounds like you are having noise issues causing communication errors.
Try running the Gcode file without the steppers or spindle running and see if you get less errors.
A high frequency spindle will mess up any system that is not properly wired with huge amounts of noise.
Are you grounding the G100 to the chassis and using a 3 prong plug with the same ground tpo the computer ? Or are you grounding the controller chassis to the cnc machine in any way (It shouldn't be ). Ethernet is not opto isolated and you don't want current flowing through the computer and controller ground.
Remember, the people who developed Ethernet and USB, didn't know anything about the noisy CNC environment ! Old RS232 was running at +- 15 volts to reject noise. USB runs at 3.3 volts and Ethernet at 5 volts
Larry K
Manufacturer of CNC routers and Viper Servo Drives
www.LarkenCNC.com and www.Viperservo.com
  #27   Ban this user!
Old 09-28-2009, 04:06 AM
plasmaboog is on a distinguished road
For the the load the FPGA there was only the power suply connect and it was a delta power supply.
But the first problem was that in the new Mach version there was no G-rex loader file anymore.
About the G-rex 100 I have ask Gecko in several emails support but I never have get a answer back about the problem, and I have try to load the FPGA on 3 different computer treu the network and treu cross link cable.
So I have send back to Gecko the G-Rex 100 and when I have make my complain by PayPal then thy have reacte.
I only have ask to send me a new one whit a FPGA program on 100megabit but the only have send the money back whit the transport cost.
So I don't have a Gecko G-Rex 100 anymore so I don't now how it head work for the project.
But my concusion is that the problem is in the Windows, And maybe there are differnets between the versions in the USA and Europe.
But I have found a firm that will make me something like the Gecko 100. And will modify his softwhere also in the U and V as whit some other small change, I have ask it on Art 1,5 year ago but he say that was not intresting for him to do.
But he forget that the same as are use in form cutting from wings for the model world.
TNC 370 communication problem Flatdog Bridgeport and Hardinge Mills 3 01-09-2008 07:20 AM
Problem G00 by Mach3 with G100 olo_3olo_3 G-REX 0 11-30-2007 07:12 PM
Fanuc OT communication problem ECM2004 General Metalwork Discussion 4 06-07-2007 07:05 AM
Communication Problem LEGCNC Machine Problems, Solutions , Wireless DNC, serial port 1 05-29-2006 08:34 PM
Communication Problem Alex S.A Computers and Networking 2 01-28-2005 09:38 AM
