Ok, this is what I get on my screen. Ive tried maximizing minimizing, reinstalling video drivers, played with setting but still cant get the screen to display the reset and open button. Strange, it works on other PCs just fine, just not mine...Any ideas |
| thats wierd as i have done that and it still comes up the same if you right click on the desktop what is your screen resolution in settings now that it is working just courious as I cant seem to get the buttons to show at all you have any sugestions and did the GrexTester.exe program work ok for you |
| My screen resolution is 1920x1200. I really have no real clue what the problem was but I dont think the resolution was the problem as I tried every possible resolution. So you cant see any buttons at all? It seems odd that yours doesn't work right after reformatting. Try redownloading the installation files from gecko and try it again. Try uninstalling your graphics card driver and trying the testor. Yes I got to the testor program to work and communicate with the pc. I had a small issue with the test.txt fill not working at first but it all works now. Ill let you know what ever I find out. Sorry I cant be of more help but I am not too great with computers. |
| I just tried to install norton works to run some tests to check for problems I ran some tests and went to uninstall it and it kept freezing during the uninstall I cant get the dang thing to boot now so I think I will try a fresh start I just orderd a new hard drive and I am ging to be carfull during the install and go from there looks like there is a file in the dounloads that help you get it set up I was just reading it called optimize XP for mach3 I believe well thanks for trying to help |
| Most people do not need to do the optimization steps. I wouldn't install any anti-virus software on the machine control PC, either. I've heard of Norton causing all sorts of problems.
| Well I got good news this time. First off, I managed to get the Grex connected again so I could load firware again. It turns out that the problem was in my Internet Protocol (TCP/IP) Properties. Try putting the following IP address and Netmask that you see (NetMask should come up automatically) see in the pic. I got this information from the Firmware documentation. and this solved it for me. If things work out you will see that the LAN cable will have connection at some point while the GREX is booting. Please ask for any clarifacations, I am happy to help |
| Thread Tools | Search this Thread |
| CNC router steppers & power supply recommendations for GREX100 with 3 Gecko G203Vs | Menatep | DIY-CNC Router Table Machines | 3 | 04-27-2007 12:15 AM |
| IIJ-Ⅱ Fully Automatic Oil Tester | fire4427zlm | Product Announcements & Manufacturer News | 0 | 02-09-2007 08:05 PM |
| 'z' problems | bo whipkey | Mach Software (ArtSoft software) | 8 | 10-10-2006 09:06 PM |
| printer port tester | smarbaga | General Electronics Discussion | 1 | 12-10-2005 12:57 PM |
| Building a Load Tester | lerman | Servo Motors and Drives | 1 | 11-06-2005 10:10 AM |
