#13
| I believe the firmware was reset to original but dont believe there was any actual testing done on it at least that is my understanding I am pursuing the software end of it and should know something more after the weekend as far as wanting to use it there is some advantages althow it seems to be looking a little less atractive as time goes on but I believe when evreything works out it will fun |
#14
| hi it would be a big help if some one could just tell me what lights come on when this is turned on I just read this (All of my dir. lights come on brightly and a very dim analog out) the onley lights that come on on mine are ch-1 on all axis just barley, very dim then the green one comes on bright when the firmware starts little help Please |
#15
| Yeah, I get the same result, the CH-1 lights come on (very dim) and then 10 seconds later the it boots up and the run LED turns green. My problem with the GREX is I cant get the firware loaded for MACH because my GREX loader cant find the grex now that the firware is loaded. Im really considering getting rid of the GREX and using a breakout board. |
#16
| I believe I have found my problem it was something simple like I thought I cant be sure until I get my computer straightened out but I am fairly sure believe it or not I had all my wires fastened down with zip ties about one every 3 or 4 inches well it seems my power cables that I am using have shrunk in length since I installed them and pulled the connectors out enough that they where not connecting might have been the change in temperature as the room is not heated I am not positive I thought all the zip ties would hold them in place but they seemed to slide threw them a little when they shrunk figured it was something like this simple and stupid and my mistake http://www.cnczone.com/forums/images...withstupid.gif |
#17
| Update: I have had everything up and working for a wile now and I love the set up Here are some suggestions 1. don’t try to run the G-rex with g340 Drives (for servos run the 320s) 2. don’t change your wiring colors in the middle of the build 3. don’t do it your own way, do what everyone says on the forum Mach 3 is a pleasure 2 axis where right on one was off but I used mach3 Told it to move one inch it prompted me for how far it did move and I typed the measured Distance in the box took about 20 minutes and now all 3 axis are consistent to ½ a thousandth I am amazed at the accuracy that’s about a close as I can measure it |
#19
| The 3rd party writing the firmware for Mach3 never finished it, and Gecko stopped selling them.
#20
That is certainly to bad, When looking back it seems like a great way get a controller on Ethernet. |
| Custom board for G-Rex G101 | Matty Zee | Gecko Drives | 6 | 04-29-2007 09:16 PM |
| G200X, G101, G100 G-rex Help | stein | General Electronics Discussion | 1 | 12-19-2005 03:38 PM |
| R2E3 success story | bkraz | Bridgeport and Hardinge Mills | 3 | 12-02-2005 01:34 PM |
| Failed transformers? | Jetlag | General Electronics Discussion | 2 | 09-09-2005 02:50 PM |
