Hi, I am working toward figuring out the wiring to my new Grex, and am looking for some input on the wiring of its power. The unit came with a 12vdc wall adapter, but also has power terminals for 24vdc and 5vdc. My question is whether all of these need to be provided, or can a 24vdc regulated power supply be used at the terminals in place of the wall adapter? Also, what of the 5vdc terminals. Any help is greatly appreciated. Thanks. |
| Thanks, T.J. |
| Take what I say with caution because I bought the G101 (Stripped down version). In that version I supply the 5V for the GRex electronics and 5-24V for the outputs (I use 12V relays so I supply 12V). From the documentation it appears that the G100 has an internal regulator to supply the 5V. If you connect a multimeter on the 5-24V out you should get 0V with the supplied adapter. You will need to supply additional power for the digital outs via the 5-24V. (max 100ma) So, yes you still need to use the supplied 12V adapter no matter what. |
| Thread Tools | Search this Thread |
| Grex G100 + Linear Encoders? | rpseguin | G-REX | 2 | 03-18-2008 04:12 PM |
| Grex-G100 | in2steam | G-REX | 11 | 03-29-2007 01:18 AM |
| Grex G100 Questions? | luis_gts | Mach Software (ArtSoft software) | 1 | 12-17-2006 11:14 PM |
| Transformer for power supply for G100/G320 | jamma | General Electronics Discussion | 3 | 09-22-2006 03:13 AM |
| Power Supply from a computer power supply | jmytyk | General Electronics Discussion | 21 | 01-11-2006 03:56 PM |
