Page 2 of 4 FirstFirst 1234 LastLast
Results 13 to 24 of 42
Thread: My new Grex Router Controller
  1. #13
    Mar 2003
    Shelby Twp, MI....USA
    Quote Originally Posted by diarmaid View Post
    So how do you input to the G100 from your computer if not using a parallel port?
    (Sorry for the basic questions and sidetracking the thread)
    ethernet
  2. #14
    Jul 2003
    california
    i know what it looks like but i would like to know where to get one. It would be nice to know where to call and order one. I am not a big fan of messing with power supplies.
  3. #15
    Dec 2004
    Mexico
    Thanks for the info Ger21, That's mean to update my Servo sistem at present using 3 G320 geckos, 3 DC servos controlled trought Parallel port.
    I Just need to add 1 Grex G-100, and I can get 4,000,000 steps per second, and this Grex will be controlled by the Ethernet or USB port, right?
    Thanks!!!
    Before you can make it, you need dream it!!!
  4. #16
    Dec 2004
    Mexico
    One more thing? How many Inputs and outputs does this G-rex G100 have???
    Thanks!!!
  • #17
    Mar 2003
    Quote Originally Posted by Yepez View Post
    Thanks!!!
    I don't know for sure if you can get the full 4Mhz step rate with Mach3. And if using mach3, you can't use the USB. Also keep in mind that Mach3's G100 support is not yet complete, although may be functional enough for your use.
    http://www.geckodrive.com/photos/G100_DESCRIPTION.pdf
  • #18
    May 2003
    Looks good. But I notcied one thing. I can't see the 470 UF caps on terminals 1 and 3 of the G201. While your motors may run smooth the internal 100 uf cap may be getting warm or even hot due to the length of the wires you have from the cap to the drivers. The only way to tell is to remove the cover.
    I always install the caps that gecko recommends across these two terminals.
    Dan Mauch
    Camtronics Inc
    www.camtronic-cnc.com
    Dan Mauch
    Camtronics Inc
    dmauch@seanet.com
    www.seanet.com/~dmauch
  • #19
    Nov 2006
    If the G100 will do that, would there be a performance differance between a G201 and a G202 if both were running with the GREX ??
    Bill
  • #20
    May 2003
    Not sured if I should jump in here but the G201 and G202 performance will be identical . Similarly the new G203 will have the same performance as the G201 and G202. The advantage of the G202 and the G203 over the G 201 are the short circuit protection and other features.
    I recently tested some G201 and some G203 on my mill drill using mach3 with a G100 and got 110 IPM on my mill drill out of both of them. I had Mach3 set for 256 khz.
    Dan Mauch
    Camtronics Inc
    www.camtronics-cnc.com
    low cost stepper and servo motors.
    assembled and tested G201,G203,G210,G320 and G340 systems.
    Dan Mauch
    Camtronics Inc
    dmauch@seanet.com
  • #21
    May 2003
    I forgot to post a link to a video of my mill drill.
    http://video.google.com/videoplay?do...ll+drill&hl=en
    Quote Originally Posted by Dan Mauch View Post
    Dan Mauch
    Camtronics Inc
    Dan Mauch
    Camtronics Inc
    dmauch@seanet.com
  • #22
    Nov 2006
    Thats kind of what I figuired Dan, that the pulse multiplier in the higher end Gecko's would have no benefit if one were to run the GREX...the extra oops protection in the 203V has many benefits however. It sure looks like if you ran the GREX AND kept your parallal breakout board(s) for other IO your switches could have switches and still have IO leftover hehe :-)
    Bill
  • #23
    Registered thkoutsidthebox's Avatar
    Nov 2006
    Ireland
    Thats such a cool video.
  • #24
    Sep 2005
    Indonesia
    Hi Ger21,
    "The G100 replaces the parallel port and breakout board (s). It doesn't take the place of the drives. The G100 creates the step and direction signals, much cleaner and faster than the parallel port. Where the parallel port is limited to 45000 steps per second with Mach3, the G100 can output 4,000,000 steps per second"
    I am interested to have G100. So GREX G100 work with Servo G320. I plan to replace my breakout board with GREX G100 and add 1 more G320 to have 4 axis. As Mariss said it will run smoother. Is it required only 1 GREX G100. Thanks. Aristo.
  • Page 2 of 4 FirstFirst 1234 LastLast
