So I've heard the G100 was overall a "failed" product... Google searches show even Mariss said it didn't do what it was intended to do and bemoaned the whole project.
However, I'm not sure what the specific problem was.
Was the firmware on the G100 itself buggy, or the hardware on it not up to the computing task?
Was the protocol flawed?
I saw complaints that it was the Mach3 plugin itself that was buggy- given the closed-source nature of Mach3 and it seems like only Art really knows how it works, I can see that as being a problem.
Was it supported for EMC2, or just Mach3?
UCCNC 2017 Screenset
Was the hardware up to the task though? And is the protocol published?
For what task?Was the hardware up to the task though?
From what I recall, the space for the firmware was not really enough for what was needed for the Mach3 firmware. The firmware was extremely complex, and only one person appeared capable of doing it, and he disappeared before completion.
The Geckodrive Yahoo group should have all the documentation you're looking for in the files section there.
So the G100 protocol is "good", but the Mach3 plugin was never finished? And Smoothstepper came in and made something which seems to have been based on the G100 project, yet it is closed-source?
Did EMC2/LinuxCNC ever make the G100 plugin, or anything like it?
No, the firmware for Mach3 use was never completely finished.So the G100 protocol is "good", but the Mach3 plugin was never finished?
The Smoothstepper was designed for Mach3 use, while the G100 was not.
Afaik, EMC doesn't support devices like the Smoothstepper or G100.
It's unlikely we will ever design another Mach3 compatible motion controller again. That doesn't mean we have given up on motion controllers though. Please see the attached pdf to see the direction we are taking. This manual is a work in progress so please excuse its incompleteness.
Mariss
