#25
| Do we know realistically how far away we are from Mach 4 being ready for general user consumption? Is the G-Rex going to simplify things for those of us whom are electronics iliterate? I'm currently at a stage where I have to decide what route I'll take. I'm very interested in the G-Rex and its capabilities however if I have to waite a year to get it all up and running then.. its probably not for me. Also if it is more complicated to set up vs a Cambell board then.. I'll be worse off as a simple B/o board is about the limit of what I understand.. and some days I'm not sure I understand even this much!! Would the largest influence from the G-Rex come from running servo's [ vs steppers]? JerryFlyGuy |
#26
| I'd guess 3 to 6 months. Since you can attach a lot more things to it, I wouldn't say it's simpler. It's very similar to a breakout board, if a breakout board had 3x the capacity. From what I've heard, it will run steppers a bit faster, because the pulses are much smoother. The benefit with servos is you can use high res encoders and not be limited by the pulse rate. For a lot of people, the biggest benefit will be all the additional inputs and outputs.
#27
| Excellent news guys, I am looking at Machine 2 and the timing is about right. 6 months I have just purchased 3 servo motors and if the G-100 can drive servos? I believe this is the way forward. Does anyone know if the Mach2-3 licence is also good for Mach4. I would assume that there has to be a Lic limitation for when second hand G-Rex boards are available in several years. /Mikie |
#28
| The G100 just outputs step and direction. You still need servo or stepper drives. And I'm pretty sure Mach4 is a free upgrade from Mach2 or 3. There will probably be an additional charge for the firmware that runs the G100, but I think complete ready to run G100's for Mach4 use will be sold, from either Art or Newfangledsolutions.com
__________________ Gerry Mach3 2010 Screenset http://home.comcast.net/~cncwoodworker/2010.html (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) Last edited by ger21; 11-22-2005 at 07:57 PM. |
#29
| Just read a note from Art on the Yahoo group. Mach4 will be a free upgrade during beta testing, or the same price as Mach3. Although possibly subject to change, when fully released, it'll be a $50 upgrade. For those not upgrading it will probably be in the $225-$250 range. plus the hardware of course.
__________________ Gerry Mach3 2010 Screenset http://home.comcast.net/~cncwoodworker/2010.html (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) Last edited by ger21; 11-22-2005 at 08:19 PM. |
#31
#32
| Hello people, Is there somebody that knows a bit on how to setup a g-rex, i tried to read the manual but its to complicated for me. so, from pc to g-rex with ethernet then the g-rex simply multiplies the pulse rate a lot is setting up the g-rex done by a pc program ???????? is there somebody that cann explain a bit about the theory off setting up the g-rex ( in simplified words, for the people that don`t have englisch for first lanquage ). looking forward to a nice thread about setting the thing up keep up the good works, Roy |
#33
| goto http://www.machsupport.com/videos.htm check out the video. Grex is only gives you a fast outrate. so you have to program by hand or use mach4 when it is out. |
#34
See here for details http://machsupport.com/forum/index.php?topic=208 |
