| G-Code Programing Discuss G-code programing and problems here! |
| HELLO MY NAME IS SONNY AND I WAS WOUNDERING IF ANYONE CAN ANSWER THE FOLLOWING QUESTION. FOR A FREE SONNYTEES.COM T-SHIRT. HURRY OFFER ENDS MIDNIGHT MONDAY FEBRUARY 22, 2010. IF CUTTERS ARE THE FOLLOWING SIZES, WHAT NUMBERS DO WE ENTER INTO THE OFFSET REGISTER FOR COMPANSATION PURPOSES? A.1/2 INCH 2 FLUTE ENDMILL B.7/8 INCH 4 FLUTE ENDMILL C.5/16 COBALT DRILL D.4 3/4 INCH 6 TEETH FACE MILL E.3/16 2 FLUTE ENDMILL F. 3/8-16 SPIRAL FLUTE TAP |
| In the offset page it should specify radius. I have never seen one specify diameter. I ass u me you are on the 21i control? So they should be entered in based on the radius of the tool. Tool A=.25 Tool B=.4375 Tool C=0 (this is a drill no need to compensate for diameter) Tool D=2.375 Tool E=.0938 Tool F=0 (this is a tap and needs no compensation) This only needs to be entered if you are going to be using cutter comp in your program or if you are gathering the radius of them via macro and system variables then calculating the compensation. Stevo |
| Problem- T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER) | dharschman | Toolgrinding & Toolgrinding Machines | 3 | 09-13-2010 12:25 PM |
| CNC Laser cutter versus CNC Plasma cutter? | squale | Laser Engraving & Cutting Machines | 10 | 04-26-2009 04:59 PM |
| Tool & Cutter Grinder and Wire Cutter Plans | newport | CNC Wire Foam Cutter Machines | 1 | 04-17-2009 04:15 PM |
| Cutter comp on an id hole< cutter diam.?? | PaintItBlue | Haas Mills | 5 | 05-05-2008 06:30 PM |
| ProE cutter compansation | javed08 | PTC Pro/Manufacture | 1 | 04-27-2007 03:46 AM |
