Results 1 to 4 of 4
Thread: G71 taper turning - why alarming out?
    Feb 2010
    uk
    System is OT, will allow taper to get bigger towards the chuck (ie Z- direction), when turning o/d with G71, but will not allow a minus taper. This works in the opposite way when boring. Alarm shown is 064, "shape program not monotonously". Now I know I've been able to do this on machines I've worked in the past, but this one doesn't seem to like it. I'm guessing this is a kind of interference check, set by a parameter - any ideas, anyone?
    Jul 2005
    You want Type II roughing, on some machines it depends whether your P line has a single axis move or two axes to select between Type I and Type II roughing. If you are already moving both X and Z on the P line then I don't have any other suggestions.
    Jul 2007
    The only way I can see you doing this is to start your cut at the chuck, and work out. The only problem is that each plunging cut at the chuck end will be at roughing speed.
    Have you thought about using G73 (pattern repeat)?
    Registered SanDiegoCNC's Avatar
    Jan 2005
    Quote Originally Posted by bullandbladder View Post
    Some machines don't like it when the lap cycle has a negative geometry in the part profile. Two ways to get around this problem; 1. keep the profile the same diameter and then make a separate pass outside the lap to cut the taper, or 2. adjust the program to allow it to taper in the positive direction. That means editing the program to make the first diameter smaller and then compensate for it in the offset page.
  1. Need Help!- NPT Taper-to-Straight-to-NPT-Taper Thread
    By bdyenter in forum General Metalwork Discussion
    Last Post: 09-16-2009, 09:10 AM
  2. Lathe turning unwanted taper
    By Hackman in forum Mini Lathe
    Last Post: 08-16-2009, 01:18 PM
  3. Need Help!- Turning a Thin part and Getting a Bad taper
    By JWB_Machining in forum General Metalwork Discussion
    Last Post: 02-26-2009, 10:26 PM
  4. Need Help!- Servo Alarming still
    By Dustin L in forum Fanuc
    Last Post: 10-02-2008, 07:21 PM
  5. BT to CAT Taper
    By machinistJ in forum Fadal
    Last Post: 02-14-2006, 03:36 PM
